-- The Home Page of the Finishing Industry
     No Pop-ups! No Spam!
HomeFAQsBooksHelpWantedsForum  ltr 4864
Serious Education ... plus the most fun you can have in metal finishing.
Coating metal with teflon resin
I need to create a small teflon rod about 1/4" dia. by 2-3" long which is stronger than a pure piece of PTFE of that size. Thus, I'm looking for information on how to coat a metal piece (any kind of metal) with teflon resin. I don't want the pan coating - it comes off too easily. I would like to coat it at least 0.040" or deeper! The use for this piece is as a barrier to push a coating across a water surface; a barrier which needs to be extremely non-reactive, strong and easy to clean. (teflon!) Thanks, Doug
Douglas Martin
University of Texas at Austin - Austin, Texas
First of two simultaneous responses-- .
Try shrink teflon tubing. If that is not thick enough, try two layers. This takes a bit of luck and a bit of skill. If you can stand thicker wall, like 1/16, Regular teflon tubing will work. Warm it in boiling water and freeze your pin on dry ice. Shove fast. Will give a very snug fit.
Second of two simultaneous responses-- .
Talk to engineers at General Magnaplate [Linden, NJ] and see if they can help you.
Mandar Sunthankar
- Fort Collins, Colorado
Looking to have several magnesium parts chrome plated, or Dow 7 finish. Plating is preferred. Is there any one in Ontario, New York, Ohio or Michigan capable of doing this? I have several contacts for California, but I would like to find a local contact for this job... Thank you;
Marty Broeders
- Woodview ; Ontario, Canada
Non sequitorial, I guess that's what you would call this letter. Mr. Martin's inquiry got a couple of good responses, to which I'll only add this: many people apparently don't realize that metal finishing is a very strongly 'job shop' oriented business. That is to say that you don't need to personally develop a teflon coating procedure in order to get a teflon coated rod. You just find a coating shop, send them your rods, and they come back teflon coated. Marty Broeders, you might want to try Luke Engrg & Mfg in Wadsworth, Ohio.
Ted Mooney,
Teds signature
Pine Beach, New Jersey
Mr Douglas, You can ask to Dupont for the nearest Dupont LIA (Licensed Industrial Aplicator)for Teflon caotings. All of them are great professionals that can help you. Jordi Pujol COATRESA Barcelona, Spain
Jordi Pujol
- Barcelona, Spain
Looking for technologies and job shops that can coat or plate carbon steel tubing and piping components with silver, gold and/or aluminum coatings.
Boyd Hanna
- Pasadena, Texas
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2016     -    Privacy    -    Search
How Google uses data when you visit this site.
