Coefficient of friction with steel greater than 0.9
I an a design engineer in the automotive field, working on a development project. I am looking for a material that has a coefficient of friction (static) with steel of 0.9 or greater. This material needs to be able to be formed, cut, punched, etc into a "washer" size piece (24 mm by about 1.0 mm thick) OR be a coating for powder metal/plate steel. If someone knows of such a material, I would appreciate any information you could forward.
brad p- Ontario, Canada
Since the coeff. of friction request (0.9) is kind of unusual, I wonder if you meant it to be 0.1. Because higher the coefficient, greater is the friction.
Mandar Sunthankar- Fort Collins, Colorado
Soft rubber tires on dry asphalt might get you 0.9. Anything at all on steel, I can't even picture it, but I'll bet the railroads would be interested.
Ted Mooney, P.E. RET finishing.com Brick, New Jersey |
Well Ted, you just gave us the nearest answer. A rubber coated steel disk may be? Brad could try a few similar coatings.
It's not difficult to achieve a coefficient of friction greater than 1. Take a magnet as an example or metals that share electrons.
Larry P- Dothan, Alabama
While that is good food for thought, Larry, I don't think it's actually correct. Coefficient of friction is, I believe, based on the normal force (perpendicular force), not the weight of the object; so a magnet does not increase the coefficient of friction, it proportionally increases both the normal force and the sliding force. By your argument for shared electrons you could weld the two pieces together as well, claiming a coefficient of friction in the millions.
Can you put "teeth" on the material so it would mesh as gears do? Alternatively, can pressure be applied against the material as in the operation of an automobile clutch?
Paul F- Colorado
What about static coefficient of rubber on steel? The conformable rubber embeds microscopically and Mu is over 1.0. Some pressure is required for this to take place, but I've seen it occur when rubber is used as a vibration damper between steel parts.
Ken K- Richmond, IN, USA
If it is a washer between flat steel surfaces a double-sided tape of minimum thickness may serve your purpose if temperature is suitable
Sumit- Pune, India
April 1, 2008
Mr. Mooney,
I believe that Larry P is correct in his statement. While the frictional force does depend on the normal force, it also depends on the coefficient of friction. The coefficient of friction is determined by the interaction between the matter of the two surfaces involved. A magnetic interaction is one type of interaction that can be considered here.
- Philadelphia, Pennsylvania
April 2, 2008
Hi, Justin. There is no doubt that magnetism can reduce slippage. When I was a kid, and that's a long time ago, Lionel added "magnetraction" to toy trains so the engine could pull a huge train without it's wheels slipping.
I am not an expert on this subject, so I don't want to engage in an "is not" / "is so" / "is not" argument on it; I'd much prefer if someone could point to a book as the referee. But I was taught that F = uN, and if the magnetic attraction increases the Normal, it increases the Force without involving a change in u.
January 29, 2009
Hi Ted,
You have it right there. The equation is F = uN. That is "Force", not weight. The magnetic attraction would add some force. This can be added to the force caused by the weight of the object.
However, magnetic force is usually tiny compared to just simply adding more weight, unless you happen to be going up a vertical wall. Or if you are working with very small objects, or you have a magnet that has a few million gauss strength.
In order for drag racing cars (wheel driven, not turbine powered) to accelerate faster than 1 g, they must produce a coefficient of friction between the tires and the tarmac that is greater than 1.
Chris Walter- Traverse City Michigan
June 11, 2009
Yes, Chris. The present world record of 4.428 seconds would seem to indicate an acceleration of 4.18 g's, which would require a co-efficient of friction in excess of 4.18.
But when rubber tires are "burned out" so that they melt into the asphalt and fuse with it, it starts getting legitimate to question whether we are really talking about coefficient of friction anymore :-)
