48028
Aluminum Basecoat/Organic or Inorganic
March 1, 2008
I need to understand the following Plating Standard: This coating
system may be specified as a water dilutable aluminum-filled ceramic
slurry basecoat only (Code C) and may be followed by a modified
organic topcoat (Code A, D or E) or an inorganic chromate phosphate
topcoat (Code B) depending on service temperatures and corrosion
protection.
This is GM spec GM 6164 M 400C as applicable for Fasteners.
Prakash Kumar
employee - Gurgaon, Haryana, India
