Letter 4680
Plate-out on contact wheels of continuous
plater
Anybody see the contact wheels of a wire plater or strip plater
build up with plating?
We suspect two things:
1). The 316 stainless steel wheels are not properly passivated. We
plan to electropolish them.
2). That there is a sneak path whereby the contact wheels of this
tank are cathodic to some other contact wheel on the line, with the
result that current is flowing through the strip and causing
deposition on the wheel.
Feedback would be appreciated from anybody who has seen a similar
problem solved.
Finishing.com Inc. - Brick, NJ
Dear Mr Mooney,
In the wire plants I have seen the contact wheels or contact
strips are made of copper only .
If I am not incorrect , I assume that your SS Contact wheels are
supposed to be cathodic in the first place so where's the question of
stray current coming from ?
Secondly the cathodic contact strip/wheel is to be mounted before
the plating tank and not after, as the solution is likely to carry
over and coat the contact material.
rgds,
Khozema
Vahanwala
Saify Ind
Bangalore, Karnataka, India
Dear Reader, please --
- Post a
question on a different subject.
- Answer or follow-up on this subject
