46083
How to assess whether a coating is
mechanical galvanizing or something else? [Italy]
August 9, 2007
hi, I have an italian customer who produces hardened fasteners has
always protected them by the means of hot dip centrifuged process.
now he is suffering competition from german and hollandaise companies
that sell a steel faucet they declare is hot dip galvanized but in
fact looks very smooth, regular coating, dark grey matte finish and
approx 85 microns in thickness. furthermore, the first microscopic
analysis revealed a way too regular coating thickness and layer, with
no presence of the usual alloy layers. Can anybody help me with
suggesting how to assess what kind of coating is that? (it is zinc
based, that's for sure)
thanks a lot
Mario Ubiali
Italy
Mario Ubiali
- Brescia, Italy
August 9, 2007
In may be mechanical galvanizing, or possibly thermal diffusion
(sort of a successor to Sherardizing) or maybe even a zinc-rich
dip-spin coating, Mario. Unfortunately, the person or company who is
offering a different coating always knows more about it than the
outsider and is always a step ahead. This means one will usually
comes off poorly if they try to demonstrate their knowledgble of
someone else's coatings.
For that reason I think the best approach in these cases is to
test which one is superior in some way. And there is certainly
nothing wrong with you deciding what those tests should be to present
hot dip centrifuged coatings in the best light.
If you think the other coating is softer, prescribe a scribe test
with a hardened knife. If you think your coating has greater salt
spray resistance, try that. Better freedom from stick-slip when
torquing up, try that. If you think the other coating is not easily
strippable, try that. I know you are already very familiar with hot
dip galvanizing, but go to some of the trade association websites and
read the advantages again and see if you can formulate tests where
hot dipping will come out on top. Good luck.
finishing.com
Brick, NJ
