46080
Do stainless steel cathodes for tin
refining exist; what pretreatment is applicable?
I would like to know if there exists stainless steel tin cathodes
for tin electro refining application? Whether the pretreatment and
activation are done by the manufacturer?
Brigitte Peck Ki Laou
recycle scrap metal - Montreal, Quebec, Canada
You need to do some homework before you jump into this. The
cathode is not activated if you want to peel the layer of tin off.
You would actually passivate it or electropolish it. The plating
chemistry gets very tricky when you use insoluble anodes which you
must do to get nearly pure tin.
