![]() (Cycles thru suppliers) |
440C parts rust ten minutes after citric acid passivation [Canada]August 8, 2007 Hi, I'm having parts made of 440C passivated following
A-967 [link is to info about spec at TechStreet] -01 Citric 4,
after being blasted with glass shot. They rust all the time after 10
minutes of cleaning in deionize water and Liquinox in an ultrasound
bath. Marc Thebo
August 10, 2007 -- 1st of two simultaneous entries In addition to the question, our pieces need to be laser engrave, that is why we are not using nitric passivation. Marc Thebo
August 10, 2007 -- 2nd of two simultaneous entries Your sentence construction makes me wonder if the citric acid is
after or before the glass bead. James Watts
August 23, 2007 James is correct. There is no reason for the 440C to rust if it is
hardened correctly and passivated correctly according to ASTM A967-01
Citric 4. This is done all the time with proprietary citric
formulations with excellent results. When done correctly it will not
remove the laser marks but will produce excellent corrosion
resistance. What hardness are you running??
December 18, 2007 So as I am reading, is it safe to assume that once the 440C is
heat treated [approx. 45 RcC] that regular Citrisurf passivation will
work and no rusting will occur on 440C? Ted Bouck
Save
