Robert H Probert Editor's
note: |
Derek,
Is this a 5% dichromate seal for anodized aluminum, a dilute chromic
acid sealing rinse for chromate, black oxide or phosphate, an
anti-tarnish rinse for electroless nickel or brass, a
post-galvanizing rinse or...? Recipes for 5 wt% dichromate anodize
seal, per 100 gallons:
The 5% dichromate anodize seal requires 43.85 pounds of sodium
dichromate dihydrate per 100 gallons of solution (balance DI water),
adjusted to pH 5.5-6.0. For small pH adjustments, 1 Normal sodium
hydroxide solution (preferably reagent grade, as used in labs) is
convenient.
Note: An equal weight of potassium dichromate (anhydrous) can be used
in lieu of sodium dichromate dihydrate. Also note, MIL-A-8625F gives
the pH range as 5.0-6.0; I suggest 5.5-6.0 is better.
To prepare a 5% dichromate solution using chromic acid flake:
Dissolve 29.43 pounds of chromic acid in DI water, raise the pH to
5.5 using high quality NaOH* (about 11 pounds) with lots of stirring
(about a 50 °F temperature rise overall using solid NaOH, but
hot spots on tank bottoms can burn plastic tank liners). Dilute to
100 gallons with DI water and adjust pH to ~5.75.
*Warning: Up to 1 wt% NaCl may be present in the cheapest, diaphragm
grade 50% NaOH solutions or pellets thereof. Use membrane, rayon or
purified diaphragm grade sodium hydroxide.
For chromic acid sealing rinses after phosphating or black oxide, see
MIL-HDBK-205A PHOSPHATIZING AND BLACK OXIDE COATING OF FERROUS
METALS.
Note: Using hexavalent chromium requires appropriate protective
equipment (such as NIOSH-approved respirators) and EPA permits. If
this is a first-time use for your company, hire an EHS specialist to
help with EPA,OSHA and local government compliance. Preferably (as in
legal), do this before bringing chemicals on-site.
Ken Vlach |
Seal on what and after what?
For Mr Probert's answer
"4. However, if it is Chromic Acid Anodizing for Boeing then use: in
100 gallon: 26 grams of chromic acid and 26 grams of either sodium or
magnesium chromate, pH 3.2-3.8, 180-200 F."
Can I lower the pH of the solution using acetic acid like #'s 1, 2,
& 3?
Dimitri Stath
- Whitby Ontario Canada
No acetic. If the pH is high, then you started with high pH water; lower the pH with chromic acid., Bob Probert
Robert H Probert |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
