46047
What dispensing equipment do we use for phosphatizing pretreatment line? [Canada]
August 6, 2007
Our company is in the process of acquiring a batch process powder coat finishing system. We do not know what equipment or where to find equipment for dispensing the phosphate cleaners. WE assume we need asome type of power washer. We also assume we need an evaporater to make dispensing of the used cleaning chemicals easier.
We would appreciate your advise.
Retter
Manufacturer - Concord, Ontario, Canada
September 30, 2007
If by dispensing, you mean metering the chemicals into the bath, you're probably looking for a standard metering pump. LMI and Prominet are two of the more common suppliers of these pumps. There are several manufacturers.
I'd suggest doing an internet search for metering pumps and contacting suppliers/distributors. Be sure to tell them what you're metering and how much you think you'll need. They'll be able to determine the best model.
Christian Restifo
- Pittsburgh, PA
October 8, 2007
The first people to ask are your chemical and plant suppliers.
They know best what works with your plant and are unlikely to suggest unsuitable equipment.
