46039
How to anodize 2024 aluminum alloy
How to anodize parts made of aluminium alloy 2024 to 25 microns
(one mil)?
What is the bath composition, bath temperature, current density and
duration?
Erol Deniz
Finishing employee - Istanbul, Turkey
Hello, Erol. 2024 is quite difficult to hard anodize or anodize to
25 microns, but it has been the subject of at least a dozen letters
here already. So if you use the search engine to look for "hard
anodize 2024" you'll get some good insights into the issue.
The thing is that our readers readily share how to do the easy
things, but when you get into the difficult stuff like hardcoating
2024, they naturally hold their successful techniques as proprietary.
The operational info that you've requested can be found in
letter 11365, but it's a long trip from
making up the bath to successfully hardcoating 2024. It's probable
that pulse rectification, additions of oxalic acid, and
extraordinarily good agitation will be part of the solution --
information which I can afford to share because I don't know how to
do it :-)
finishing.com
Brick, New Jersey
