46029
Student needs help quantifying corrosion
development
Hello,
I'm a french student and I have to qualify and quantify the
development of the corrosion process on simple square samples (50 mm
x 50 mm x 2,5 mm) of different materials (A2 and HSLA). The
experiment is set up in a conventional salt spray room.
I already use the corrosion rate (mm/year) and the visual
developpment of uniform corrosion on the surface. Is there any other
tool or rate to quantify and qualify the development of corrosion.
Thank you for your help.
Gautier LACKER
Student - Toronto, CANADA
I think you should try to get some U.S. mil specs, which are
available free (see our FAQ), in
order to understand the concensus that people have come to as to what
constitutes acceptable resistance vs. unacceptable corrosion of
different products. That way your efforts will relate not just to
measuring the corrosion but understanding how others measure it, and
its significance for practical applications. Good luck.
finishing.com
Brick, New Jersey
