46008
Badly need guidance on Albaloy plating
bath analysis
Hi, my name is jerry and I'm a plater for a electronics company.
My question is about the albaloy bath I use. Can I determine the
copper, tin, and zinc concentration by using titration methods? My
vendor tells me the only way is by AAS. I am currently using an x-ray
machine but, this method seems to be inaccurate and inconsistent. If
I can use titration methods PLEASE, can you tell me the procedure for
each metal?
thank you,
Jerry Hannibal
lead person - Beverly, Massachusetts, USA
Hi Jerry
You should be able to use your x-ray machine for all three of these
metals - especially if you are trying to measure them at g/L or %
types of levels. I would use the method of standard additions and it
should work.
Terry Tomt
- Auburn, WA
A Google search on "Albaloy" tells me that it is a cyanide based
alkaline formulation, also known as "white bronze."
Zinc can be determined as in a brass solution: titration with EDTA
after blending with a pH 10 NH3/NH4Cl buffer, and a formaldehyde
addition. The indicator used is eriochrome black 'T'; the endpoint
transition is red to blue.
Copper, plus zinc, will come up in an EDTA titration also. The
cyanide is destroyed, via the addition of hydrogen peroxide, and
subsequent addition of HNO3 and H2SO4 (caution! cyanide gas
released!)and heating to white fumes. Water is added after cooling,
aqueous ammonia added just to a blue color, PAN indicator solution
added, and the mixture titrated at about 140 F with EDTA to a light
green endpoint. A little arithmetic, subtracting the Zn number,
yields the Cu number.
Tin can be determined as in a bronze solution. A suitably sized
sample is combined with about 40 ml of conc HCl (caution! cyanide gas
released!) and heated until gas evolution ceases. About 60 ml of
water and 2 - 3 g iron powder are added, and the mixture boiled until
the iron dissolves. About a gram of NaHCO3 is added, the mixture
covered loosely, and allowed to cool. A bit of starch indicator is
added, and the mixture titrated to a blue endpoint with iodine
solution.
If I was mistaken about this being a cyanide formulation, and the
complexant is some kind of organic chelator, the zinc determination
has to be finagled - a good sharp acid digestion, followed by ammonia
addition to pH 10, will get rid of the chelator and allow titration
in the usual fashion.
Dave Wichern
- The Bronx, New York
Minor emendation: If you do the acid digestion for Zn in a
non-cyanide formulation (if that is what you have) after the post
digestion elevation of the pH, you need to add 300-400 mg of sodium
cyanide to mask the copper. When you add the formaldehyde, the zinc
will be unmasked, but not the copper.
Dave Wichern
