46007
Iron Phosphatizing Safety and Waste Water
Issues
Can anyone help me find out about the safety issues with Iron
Phosphatizing and any wastewater issues. Are there any articles out
there that discusses these issues. I need as much info as I can get.
Rosy DeSimone
Employee - Kansas City, MO, USA
Ed. note: Rosy asks our supporting advertisers to call her on
this.
Iron phosphating is a Federal categorical process, with defined
pretreatment discharge limits. The most likely contaminant in spent
rinse water is zinc, if you are applying this coating on galvanized
steel. An adjustment of the pH to 9 - 9.5, followed by the addition
of flocculant, and settling, should leave the residual Zn in the
decant below this limit. (monthly average = 1.48 mg/l; daily max =
2.61 mg/l)
Your local POTW may have restrictions on the discharge of iron and/or
phosphorus. Get with them and see what their policy is.
Both the settled sludge from this operation, and the tank bottoms,
are categorical hazardous wastes. They need to be dewatered, and
hauled to a haz waste landfill.
Dave Wichern
- The Bronx, New York
Phosphatizing is a listed process in Section 433 of EPA
regulations for the Metal Finishing Category. However, if you are
doing iron phosphatizing and not zinc phosphatizing, you may not have
any worries, since iron discharges are not regulated in these
regulations. However, as the previous responder noted, zinc and
nickel (a common ingredient in zinc phosphate coating solutions) are
regulated.
Most iron phosphate operations that I know of have no waste treatment
other than possibly neutralization. These operations often haul any
concentrared dumps off-site for treatment and disposal.
Even if there are no Federal Regulations that apply to your
situation, you would still need to meet the requirements of your
local sewer use code. Many local codes allow up to 50 mg/L or more of
iron, and allow a fairly high concentrate of phosphates before any
surcharge would be levied. So, if you are just doing iron phosphate
coating, I suggest that you contact your local sewer authority for
advice.
Lyle Kirman
water treatment systems - Cleveland, Ohio
