How much corrosion resistance from chromating nickel [North Carolina]August 2, 2007 Is there a commercially available chromate for bright nickel and is there any corrosion data to show how much corrosion resistance is improved. Thomas Christian
August 3, 2007 To my knowledge you cannot do a chromate conversion coating on nickel. However, it would not surprise me to be advised that there is chromate in the tarnish-ban post treatments sometimes done on nickel. I think you should inquire of Technic or another supplier of nickel and electroless nickel post-treatments as to whether there is chrome in them and how long they can be expected to keep the nickel from tarnishing.
August 4, 2007 -- 1st of two simultaneous responses Could there be a confusion of terms and you are talking about real chrome, Thomas? G. Marrufo-Mexico Guillermo Marrufo
August 4, 2007 -- 2nd of two simultaneous responses The tendency for bare nickel to corrode will be reduced by a mere dip in ANY hex chrome containing solution including the rinse water following the zinc or aluminum chromate. This will not be a "conversion coating", but it will deter tarnish.
Save
