45737
Help ELECTROLESS polish the ID of a small
stainless steel tube. Chemistries?
Hi folks,
I have a question I am hoping the users of this forum can help me
answer.
I would like to chemically polish the inside diameter of a 0.030" ID
stainless steel tube, about 2-3" long. This piece of tubing will be
used to make a length of microwave "waveguide", and so I would like
to have a very smooth, clean surface with a well known initial
ID.
Electro-polishing is out of the question. We've tried it with poor
results because of the very small wire diameter and more complicated
mechanics required. I've also tried mechanical polishing with dental
floss and abrasive, and besides being tedious it didn't work so well
either.
Others have suggested in the past that I purchase pre-polished
hypodermic grade tubing to start with, but it is difficult to obtain
small quantities of steel tubing with a 0.030" ID to begin with. I am
lucky to have what I have.
What I would like to do is find an appropriate solution or solutions
that can be pumped through the tube using a tubing pump. I need an
actual chemical *polish* that will remove surface irregularities in
addition to scale, rust and debris inside the tube.
I know there are some companies that do this, but generally they
don't want small quantities of stuff, and it would be very much more
convenient to do this in-house, as we have a reasonably equipped chem
lab. Furthermore, lots of commerical places use proprietary
chemicals, so it will be impossible to know exactly what they did in
the future if I need to repeat the process.
So, I am hoping someone can suggest some chemistries to chemically
(electrolessly) polish steel that I can try in-house, OR recommend a
shop that will do small jobs with a relatively sane turnaround
time.
Thanks in advance for any suggestions.
Daniel Koller
Researcher - Charlottesville, VA, USA
Although electropolishing is no chip shot, neither would I call it
out of the question, Dan. Can your waveguide be made of copper,
nickel, or gold instead of stainless steel? If so you could
electroform it on a .03" diameter wire mandrel and the ID would be
every bit as smooth as the OD of the wire.
finishing.com
Brick, New Jersey
Nope. It's intended to be a thermally-isolating section of
waveguide. WR-3 rectangular waveguide (0.034" x 0.17") is
commercially available in coin silver, but not steel. So I am using
the round stainless tube as a substitute, which is already a
compromise. That's why I'd like to limit the loss as much as possible
in the tubing I have. We have extensive electroforming capabilities
in-house, but it's not an option.
I've sent a sample off to a stainless micropolishing company in
California, and they claim to have an electroless steel polishing
technique. I have not gotten the samples back yet, but I understand
their dip solution is proprietary. Anyone have any Idea what they
use?
Dan
Daniel Koller
Ed. note: the internet is too anonymous for us to want to print
replies to your closing question, Daniel.
