-----White gold stained by hot ovens!
I have a white gold ring and I worked at a bakery .. I accidentally had my ring touch the hot oven and a spot turned a very faint gold color... I want to know if I can clean it with it having a ruby stone or ... should I let professionals handle this? or is it permanent?
Eva Altaconsumer - Los Angeles, California, USA
Eva,
If the ring is a true white gold casting, the ring can be professionally polished, if it contains a genuine ruby stone the polishing should be done by a reputable jeweler. Good Luck!
Process Engineer - Syracuse, New York
