finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 45090
Looking for job shop to chrome plate some zinc die cast bezels
I have 200+ zinc die cast bezels that I need to have polished and chrome plated. This is an automotive trim part for old Buicks. It is part of a center cap assembly that goes into the center hole in a chrome wheel and the quality needs to be high as these are used on collector cars. The castings are clean but will need to be polished/buffed prior to plating.
I can send samples and a finished part for review prior to quoting. The part is approximately 2.75 inch in diameter and 1.25 inch high with a 2 inch diameter hole in the center. In the past, many platers that I have used were unable to achieve a decent plating on the bevel that runs around the hole. If you see the part, you will understand the issue.
Mitch Romanowski
Designer - Palatine, Illinois, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
