45046
Extracting nickel in metallic form from
an alloy [Iran]
May 9, 2007
Hello,
Due to relatively high price of nickel, I'm intrested in extracting
nickel from an industrial waste alloy which accounts for 17.7% of
it's total weight.the base of this alloy is copper and trace amount
of other elements is present. my questions include:
1. is there a specific acidic solution which dissolves nickel but not
copper or vice versa?
2. if not, by decomposing the alloy with concentrated nitric acid
which method is proper for nickel extraction? WATTs nickel bath,
electroless nickel plating, sulfide formation-reduction with respect
to huge amounts of copper ions that do interfere in electroplating of
nickel or sulfide generation.
Hooman Jackub Nejad
student - Isfahan city, Isfahan, Iran
May 10, 2007
If the metal is an alloy,it is homogeneous and you would have to
dissolve all of the metal. Now you have a solution of the metal ions
which are very hard to separate.
Sell your metal for scrap as recovery will cost you more than you
will get back for it.
- FL
