-----Bromine in Water Corrodes Stainless Steel
I am designing a grating system to line a fountain that contains about 5 ppm bromine in the water, and I'm wondering if 316L will be sufficient enough to withstand corrosion. If not, I have heard that fluoropolymer coatings can help. would a fluoropolymer-based powder coating do the trick?
Jason T [last name deleted for privacy by Editor]engineer - New Brighton, Minnesota
