Hot black oxide (blackodize) vs. cold blackening
     The 'black oxide' process is usually called 'bluing' when applied to firearms. Hot bluing/black oxiding is done in a tank of concentrated caustic soda plus oxidizing agents like nitrates and nitrites, operating at a slow boil. Depending on the concentration of salts in the solution, that boiling temperature will be between 265 °F and 300 °F.
     A special, severe danger with this process, which has maimed and killed people, is 'eruption': water must be frequently added to make up for evaporation losses, but water flashes to steam at 212 °F, so there is the possibility of a slug of water encountering this much hotter solution and, instead of mixing with it, flashing to steam and blowing the contents of the tank onto an operator.
     Cold bluing / room temperature blackening is a safer copper selenium coating process which simulates real hot bluing although it is not as consistent or corrosion resistant; although it's best suited to touch up, it has also been used industrially in some instances.
Q. I work in a tool room as an apprentice and would like a comparison of durability between black oxide done with the cold method and the hot method. Thank you very much.
Thomas M. Herpel
1997
A. Room temperature blackening with proprietary solutions is more expensive and less durable, Thomas, and doesn't look as good. Whether it will prove "durable enough" would depend on the application, but the cold blackening processes that I know of deposit selenium compounds on the surface, which do tend to rub off as a smut. Hot black oxiding is a nasty, dangerous, process though. So, if the durability of room temperature blackening is sufficient for you, and the cost is affordable, it may be worthwhile :-)
You may be interested in our FAQ on Black Oxide & Cold Blackening, and further info can be found in The Metal Finishing Guidebook. Best of luck!
A. Tom,
Ditto on what Ted said. A well done hot process looks a lot better and my gut feeling is that it is ten times as durable as a well done cold process. The cold process is adequate for most of the tool room uses. Have done both and unless you absolutely need the better protection of hot, use the cold. Hot is going to cause you some problem with EPA more so than the cold. Personal feelings.
"Firearm Blueing & Browning"
by R. H. Angier
angier_firearmbluing
Q. I'm very interested in the cold process for auto parts for personal use and want to find a local dealer for the chemicals. However I have the background to set up a small garage based unit for local hot rodders. Any help will be appreciated.
John g. [last name deleted for privacy by Editor]
Ed. note: You can try EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser] for cold blackening processes; they are well known for them, but I'm not sure if they will sell to a non-registered business due to product stewardship and liability concerns. For personal use you can get bluing/blacking chemicals on line on eBay or Amazon [affil link]
As long as you are not foolish or reckless, you're probably going to be okay with your hobby, but as soon as you do chemical metal finishing as a business, well ...
A. If you do, that will make you a Hazardous waste generator. Suggest that you check with your region of the state EPA and with your local sewer folks before you go any further. You probably will change your mind. Minimum fine is substantial if you are caught. If an angry customer turns you in, they will visit you to clear the complaint.
thumbs down sign Response to John G. If you really have the proper background to install a mini plating shop in your garage, then you should know you will be exposing children, pets and neighbors to dangerous chemicals. You should also be aware that you will have chemicals and waste water to dispose of, and that you need a city permit, a state permit and EPA clearance to do all of this.
Are you prepared to put in a separate sewer line, pay the business fees and license fees to all the proper agencies, or take the livelihood from an honest, reputable plating shop that does all these things.
Lee Garcia
- Reno, Nevada
Q. I would like to know about:
1. Room Temperature Blacking Method of Iron and Steel.
2. What are the Advantages and Disadvantages compared to Hot Blackening/Oxidization process.
3. Which web sites I can visit to know more about the process and the various manufacturers.
Hemant Manek
- Calcutta, India
Usually available on eBay; sometimes on AbeBooks or Amazon
(affil links) mfg_online
A. The principal advantage of cold blackening is that it is far safer to operate than the hot process, which involves a boiling hot highly concentrated aqueous solution of caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] which, if not handled properly, can erupt and burn or kill people. The operating temperature of hot black oxide tanks is much higher than the boiling point of water, such that when water is added to make good the evaporation losses, it has the potential of instantly flashing to steam and blowing the contents of the tank all over the place.
Cold blacking chemicals are more expensive, do not have equivalent corrosion resistance or the shiny uniform appearance of hot black oxide, and can rub off as an abrasive grit which can be a problem in certain manufacturing processes.
We have a FAQ on Black Oxide & Cold Blackening which may be helpful, and if you can find a copy of the Metal Finishing Guidebook, it will probably have a chapter on the subject. Good luck.
Q. James,
Which process would make me more of a hazardous waste generator, the hot method or the cold? Do you know of any documentation comparing the waste concerns of both methods? ⇦ Answer?
Bob P.
- Toronto, Ontario, Canada
thumbs down signYou people make way too big a deal out of this EPA stuff. I've been plating copper and nickel, and anodizing aluminum for YEARS in a very visible, well known shop 1 block from a county wastewater treatment facility, and have NEVER EVER EVER even spoke to one single EPA or any other agency representative. I have no special sewer line, nothing. I collect any wastewater I have in HDPE 50 gal drums and have it picked up by a local environmental service company who disposes of it for a fee. Stop trying to discourage people from getting into the hobby by throwing a bunch of legal mumbo jumbo at them. Why even bother to have this forum if all your gonna do is try keep all this century old plating stuff a "secret" just so you can make more money? A small 2-5 gallon plating line can be built anywhere, garage or basement included.
Mike Horan
- Atlanta, Georgia
thumbs up signWe're very happy to publish anyone's opinion, Mike!
It is one thing to use chemicals as a hobby. But if you sell metal finishing services as John G proposes, you are operating a plating business, so please glance through EPA40CFR, especially the subheadings on waste water, sludge accumulation records, nitrate documentation, and air emissions estimating; or attend a hazmat course offered by AESF, or Lion Technologies, or your local community college. Go to the library and read a couple of issues of Plating and Surface Finishing, Metal Finishing, or "Products Finishing", or attend the annual plating industry/EPA meeting in Washington DC. Then try to explain to yourself on what grounds you could possibly think that a metal finishing business could possibly become exempt from those regulations.
You ask what good is this forum if it doesn't encourage amateurs to go into the metal finishing business? This forum is directed both towards professionals and their shop problems, and hobbyists, artists, & homemakers and their metal finishing questions -- but it is not directed at tempting people to risk injury to themselves, violate the law, or jeopardize the public safety.
thumbsdown Curiosity has me in it's grip today.
I do gunsmithing once in a while. So far, sending parts out hasn't been too tough, but I'd like to add to my in-shop abilities. Some things MIGHT be better if I had some control over them myself. Getting parts back plated too thick, or not masked properly...
I found, well, Ted's response a bit presumptuous, and rather inflammatory. Ya, it was a flame...but a semi-informative one. Listed a few areas for me to look into...
Being interested in the plating/finishing processes, I'd like to know more about the laws involved, and what needs to be done to actually DO some plating/finishing on my own once in a while. Truth be told, it's MY judgment call as to what will be "too expensive" to justify it. Likewise with the legal research. It's MY responsibility to ensure I conform with law, specifically those that would apply to ME: MY application, quantities, location, whether to hire a lawyer to find all of this out, etc...
Case in point: Some businesses ARE EXEMPT from OSHA. Law is not always the same, it's up to the individual to make sure they comply to whatever laws applicable. Real Estate businesses are exempt from OSHA, BTW...Supposedly not enough injuries per year to justify inspecting them...Hmph...
Anyhow, rather than blow someone off with a flame, next time do it with some finesse. Information shared responsibly, AND IN A MANNER THAT IS USEFUL, is worth a lot more than some cheap shot at the auto parts plating guy.
Enough to think about.
Take Care,
RJ
Robert J [last name deleted for privacy by Editor]
- Berthold, North Dakota
thumbs up signHi Robert. Your posting reminds me of the way zealots react to politics. If they agree with one side, they see that side as "only saying what needs to be said" no matter how vicious or misleading and they see the other side as engaging in "attacks" if they even challenge misleading claims  🙂
I warned Bob that hobbies are one thing but businesses are another as far as regulations are concerned, James Watts & Lee Garcia warned him that there are EPA problems involved in operating a shop with this kind of chemical processing. To that, Mr. Horan responded by saying we 'make way too big a deal' of it and were 'throwing a bunch of legal mumbo jumbo' at people. He implied that our website is worthless. He closed by saying that my motive for the long years I've put into this site was to 'keep things secret' so we could 'make more money' by discouraging people from the business.
You didn't see those repeated, provocative, personal insults as a flame, but you saw my response as one?
I gave the volume number of the code of federal regulations that people should look at, and which subheadings to look under; three places people could get training on the actual laws; the principal journals serving the industry if anyone wanted to learn more; the location of the annual conference where EPA keeps metal finishers advised of those regulations. And you considered this as 'blowing him off', flaming, and not sharing information in a 'manner that is useful? Oh well.
EPA 40CFR413 and 40CFR433 make no exception for the size of a business. However, if someone is processing parts only for personal use and they neither sell a finished part nor their processing services, they are not in business, and these federal regulations probably do not apply to them. And just because someone does chemical processing, they're not necessarily a plating shop; the regulated category they fall into, if any, does depend on the situation as you say.
Q. Does anyone know if you can successfully chemi black EN31 Carbon Steel?
Louise Boyle
Production engineer - Glos, UK
A. EN 31 = DIN 100Cr6 = SAE 52100. A high carbon, high chrome steel with high hardness and wear resistance. Commonly quenched & tempered to HRC 62. Composition is
C 0.98-1.1, Cr 1.30-1.60, Mn 0.25-0.45, P 0.025 max, S 0.025 max, Si 0.15-0.30, bal Fe.
It likely can be blackened by either the conventional hot black oxide or room temperature chemical processes. I haven't any experience treating this alloy. Due to the levels of C & Cr, it is perhaps treated as a 400-series stainless steel. Anyone with more info?
Chemical suppliers may be able to refer you to local jobshops having the appropriate treatment solutions.
Ken Vlach [deceased]
- Goleta, California
A. The EN31 (400) series material can be treated with low temperature chemi-black systems that operates at ambient temperature.
Barry Clements
- Coventry Warks, UK
Pretreatment for Hot Black Oxide?
Q. For your info -
I run a small 3-man engineering shop and use a proprietary supplier to supply me with cold blackening chemicals.
For a shop as small as mine, the process is probably a little expensive, but the benefit is being in control of your product from start to finish, controlling your own lead time on job completion, etc.
In my experience it is correct to say, though, that hot black oxide processes are much better quality.
As my company expands I am now looking into the hot process.
What process is used for cleaning the part before hot blackening?
When I cold blacken I first have to sandblast the part if it has any mill scale left, unless it has been machined, then it can go directly through the cleaning agents provided by the supplier.
What is the process with hot blackening?
Ben Pearson
- Goulburn, NSW, Australia
A. Those steps will be the same, Ben. Scale must be removed, then the parts thoroughly alkaline cleaned before putting them in the hot black oxide tank. Usually there will be a post-dip involving a wax or oil.
The biggest difference is that hot black oxide is quite dangerous. The problem is that the process operates at about 290 °F so there are evaporation losses, and water must be frequently added. But water flashes to steam at 212 °F. So, if a good slug of make-up water finds itself surrounded by this 290 ° solution, it can flash to steam, propelling this hot concentrated caustic onto an operator. Some people have been killed and many severely burned from these eruptions, so extreme care must be used to prevent it from happening, and protective gear worn in case it happens anyway. Good luck!
Q. If properly rinsed after the black oxide bath, should a hot-process black oxide leave smut residue when handled?
Parts I am receiving from a supplier leave a black, greasy substance, and since the parts will be handled by a customer, I'd like to minimize this. It seems to be after finished in oil. Rinsing in isopropyl alcohol removes most of the smut but also some of the finish.
Jimmy
James Heisler
- Austin, Texas
February 4, 2008
A. Hi, Jimmy. You can have a different oil applied that is less smutty, or a wax instead. But a black oxide finish derives almost all of its limited corrosion resistance from the oil or wax. If you remove it, it will flash rust.
Q. I'm working for someone who is interested in possibly starting a hot black oxide business and I noticed that someone said that a permit was required for plating, but I wasn't sure if that applied for a black oxide finishing company. From what I've read, finishing and plating are different so I was wondering if the law requirements were the same.
Kirsten Haney
- Acton California United States
May 19, 2008
Acronyms:
POTW = publicly owned treatment works
A. Hi, Kirsten. I'm not seeing black oxide mentioned in EPA 40 CFR 433 (www.access.gpo.gov/nara/cfr/waisidx_98/40cfr433_98.html ), so it's possible that an EPA permit isn't required. But you should check with a local field office of the EPA, or with your POTW. Good luck.
Update: The above link is broken. Thankfully, the Wayback Machine saved a copy here.
wayback2
Please consider a donation to the Internet Archive; it's priceless in this age of temporary, changeable digital records, but under constant costly legal attacks. Don't follow old URLs; they're sought by hackers to get unsuspecting visitors from legitimate sites!
thumbs up sign I have 35 years experience in Electroplating and spray painting in Defence organ., I like to answer any question on the above subject. Presently I am working as Manager in electronics company in Bangalore, Karnataka, India.
chandramanipg
- Bangalore,Karnataka, India
October 22, 2008
Ed. note: Welcome, Chandramanipg. We have thousands of public questions on electroplating & spray painting where your input would be greatly appreciated. Just find any questions that interest you at finishing.com/letters and jump right in.
But it would be rude to invite people to my home for cocktails, then at dinnertime tell some they didn't make the dinner cut and should go home; for the same reason we don't intrigue the readers with Q&As, then cut them out from the final answers by letting discussions go private.
thumbs up sign OK, Robert and Ted,
Firstly, I understand where Robert is coming from on the subject of process control for his own shop and the frustration that comes with dealing with certain members of the metal-working community. Are there people so frightened by competition that they will keep their methods such closely guarded secrets? Sadly, yes there are. Are these folks so motivated by their fears that they act like some sort of overly fraternal secret society with weird hazing rituals; kinda like all the rumors about skull and bones and Free Masons? Again, sadly, yes there are these sorts of people in the industry.
But see, I don't think Ted is one of them. Everything he said to the people in this post that you might find discouraging was, in my opinion, quite highly informative. He spoke of the hazards involved with the procedure and the laws governing it. There is an iron-clad reason why these laws exist and why chemical processes of ANY kind are so closely regulated. As Ted said, the Black Oxide, as with most chemically induced finishing methods, can be harmful in a way that is life-altering and potentially life-ENDING. Think about it THIS way: Why is there no such thing as a NUCLEAR POWERED CAR? We could certainly produce one. But then think of all the horrors offered up by the mere NOTION of the "Shade-Tree Nuclear mechanic." When thinking about it that way, the reasons become clear.
Thank you both for your opinions, and thank you Ted for the information. I came to this post out of curiosity about the cold process vs. the hot process as I work in a tool and die shop where we use the cold process all the time to NOT SO ATTRACTIVE results. I was thinking about recommending the hot process, but after reading this post, I'm not so sure. If our customers are satisfied with the process we employ; why take the added risks?
Tom Knoblaugh
- Louisville, Kentucky
September 3, 2012
Gun Bluing
birchwood-casey_bluing
A. Hi Tom.
My understanding is that all cold blackening processes rely on a deposit of a selenium sulfide compound on the steel, not an actual black oxide. My limited personal experience is that even the best of these are "smutty" (rub off fairly easily, leaving hands or cloth dark). Hot black oxide is, in my opinion, a nicer looking and superior finish. But the high temperature does present the safety issue I mentioned.
In one case that I know of, someone tossed a can of soda to a co-worker, but it missed and landed in a black oxide tank where it flashed to steam, exploding that hot caustic onto the operator and killing him. Everyone treats a pot of boiling water with deference, and these tanks are much much bigger, much hotter, and filled with concentrated caustic rather than water. So hard hat, face shield on eBay or Amazon [affil link] , apron on eBay or Amazon [affil link] , gloves on eBay or Amazon [affil link] , and boots is not at all excessive in my opinion ... and they would be a requirement if I were the supervisor. Good luck.
Q. What is the modern bluing now?
Today what is the better way to do the modern cold bluing or the traditional bluing?
Someone help me to answer my question please.
kabz juezan
- dubai, uae
May 4, 2015
A. Hi Kabz. Both are widely done because neither is "better" ... it depends on which parameters are most important to you. However, there is little question that hot black oxiding produces a nicer looking and more corrosion resistant finish. As you see, we appended your question to a thread which already addresses it. Good luck!
Q. Hi Ted,
Thanks for giving me an idea.
Can I ask more questions: I'm working now in a government company and I don't have any idea what's the better process. I will do the hot bluing or the spray-on, bake-on finish process? and I don't have also the idea of the man-hours of both processes because this is my first time I will do this kind of work. And we're planning a small arm and a big arm that will undergo bluing or coating. Can you give some advice what's good to do, where the man-hours also are short and can produce more finished products.
Thank you so much.
Regards, ave
kabz juezan [returning]
- dubai,uae
May 8, 2015
Cerakote
Starter Kit
cerakote
A. Hi again Kabz. The reason so many different finishes are available is because none of them is all-around superior to the others. Manufacturers with decades of experience have difficulty choosing, but Step 1 is always to have sample parts finished and tested before you consider building a factory to mass produce a mistake.
Still, here's one thing for you to consider: bluing, even hot bluing, doesn't offer much corrosion resistance. It's a beautiful finish for those who will lovingly maintain their favorite hunting weapon, cleaning and oiling it after each outing. But as a robust finish for mass produced and mass distributed arms? ... I don't think so. The spray-on and bake coating sounds more applicable. But there are many other choices including electroless nickel plating, salt bath nitriding, and Cerakote.
As for man-hours, I think you would need to hire a consultant to work through all of the issues with you. Estimating the man-hours involved in a whole manufacturing & inspection sequence is a big job. I am personally not interested in cheapening stuff anyway. I'm for sustainability, whereas perpetually re-manufacturing stuff that doesn't last due to cheap, poor finishes represents wastefulness that the planet can't afford :-)
Regards and good luck,
Q. Dear sir,
I am planning to start BLACKENING process in our company only. Can you suggest what and all need and how to start new process sir? ⇦ Answer?
Hemant Kumar
Hemant Kumar
- Florida, USA
August 16, 2015
Q. Dear All,
Could you please help to make a continuous cold blacking or cold bluing for uncoated steel strip to get high corrosion resistance with blackening? Please help to apply a thin coating (1 micron max) on steel strip with an acceptable opacity and good coverage.
Line speed around 60 m/mint. ⇦ Answer?
Salah Salman, Product development
steel - Cairo, Egypt
thumbs up signHi Hemanth; Hi Salah.
People are very welcome to try to help you if they wish, but it looks like they're not doing so this time.
This forum is good for directing people to sources of information, which began with the first response on this page, and it's also very good for answers to highly specific queries. But it can't replace a consultant; it's probably quite unrealistic to hope that a reader will design a process line for you for free via this forum, but good luck. After reviewing the recommended resources, please try to ask some highly specific questions. Thanks!
Want cold blackening with shades of gray
Q. I haven't found anyone in Brazil who has experience with black oxide for architectural purposes so I have been researching your site and working with a small metal shop in order to try to create cold blackened steel panels to cover a large kitchen wall. We are getting close using the selenium copper compound however our results still don't have that beautiful dark grey finish with lighter and darker variations. We are using 20% copper to 80% selenium on 1/8" steel sheets and leave it approximately 20 seconds. The result is either totally black, if left too long, or it has a reddish-orange tint. Any suggestions how we can achieve the desired coloring?
Mitchell Tremsky
Architect - Rio de Janeiro, Brazil
January 24, 2016
A. Hi Mitchell. That sounds like an interesting finish! Unfortunately I'm not personally familiar with it, and the only cold blackening that I know is actually black. You can try contacting EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser], who specialize in cold blackening, or hopefully a reader will be familiar with your need.
Black oxide counter top
Q. I am investigating blackened steel kitchen bench top. Concerns from reading above would be reliance on a seal for corrosion prevention. Given only kitchen bench would a non sealed work. I got the impression blackening was done in first instance to stop corrosion.
Thanks in advance.
Darin Millar
- Christchurch, New Zealand
February 22, 2016
Butcher's Wax
butcher_wax
A. Hi Darin. Try a small and simple one first and let us know how it works out because I have no experience with it. A "dry" hot black oxide would probably be highly subject to rusting, but if you keep it waxed with butcher's wax or oiled with mineral oil, my guess is that it will be okay. Remember that petroleum oils (which would be the most commonly applied oils) are poisonous!
Cold blackening toxicity?
January 28, 2017
Q. I'm looking at black oxide treatments for shop-made tooling--clamps, step blocks, boring bar adapters, that sort of thing. Typical materials are 1018 and 12L14 cold rolled steel, maybe some O-1, D-2, or S-7 tool steels on occasion.
The actual black oxide processes, even the ones at lower temperatures (220 vs 290) are wickedly dangerous due to the caustic sodium hydroxide, flash-over, etc.
Hence I'm looking at the cold black options. If I understand it correctly, these put a copper/selenium coating on the steel My concern with them is the selenium content. Selenium and its compounds are very toxic, with an LD50 on the order of 1-3 mg/kg body weight.
How safe is it to handle parts with a cold black treatment on a regular basis?
Paul Ste. Marie
hobbyist - Renton, Washington, US
A. Hi Paul. These are proprietary processes, so I think the suppliers' material safety data sheet may offer good info. But I think a cold blackening will wear away from handling pretty quickly.
Q. "... I think the suppliers' material safety data sheet may offer good info."
Unfortunately, they discuss the toxicity of the ingredients (selenious acid in particular--"may be fatal in small amounts"), but not the safety of the finished item.
Paul J. Ste. Marie [returning]
- Renton, Washington USA
February 7, 2017
Cerakote
Starter Kit
cerakote
A. I don't think cold bluing is a good process anyway for parts that will be handled. Where tolerances aren't critical like clamps, Cerakote or CED may be preferable. Where no dimensional change is allowed, maybe waxed hot black oxide?
birchwoodYouTubeBlackOxide
