Cycles thru suppliers.
44069
What is zinc ash and bottom dross loss?
What is the normal ratio of the Zinc ash and bottom dross compared with the consumed Zinc in hot dip galvanization and how I can recover pure Zinc from the ash and dross effectively. I am a manager and producing galvanized wire by hot dip process and the Zinc lost through dross and ash is really bothering me much.So far I remelted the ash (big sizes) in a curicible and recovered metallic Zinc.I have also used ammonium chloride but not found very effective.How can I increase the effectiveness.Is there other additives to mix with the ash and dross?
If you could give me some recommentation it will be very appreciated.
Süleyman BEÞLÝ
ÖZYAÞAR A.Þ - Silivri-ISTANBUL, TURKEY
Could you please answer how I can reduce the smoke(fume) created during hot dip galvanization on the Zinc furnace and reduce the zinc ratio retained in the ash?
Süleyman BEÞLÝ
--ISTANBUL, TURKEY
List of Directories
