Letter 4215
Dave Wichern |
Hi Gerald ,
Why bother with the complexities of Ion exchange for recovery of precious metals , there are many fine "Plug-in" units available for electrolytic recovery from Drag-outs & even running rinses .
If you want to persist with the ion exchange then call Resin Tech of Cherry Hill New Jersey , they are masters in using the right resins .
regards
John Tenison - Woods
- Victoria Australia
Jerry,
You should have no problem recovering gold using strong base anion resin. The only strong "chelator" in most gold baths is cyanide, unless you are using a sulfite system, or you have a acid gold chloride strike. The gold is in the form of a gold cyanide complex which exchanges quite nicely. And free cyanide comes out on the SBA resin as well.
The problem you will have is that the gold cyanide won't be fully removed if you try to regenerate the resin. You are better off just sending it to a refiner to have it ashed for metal recovery when the resin is loaded.
Bill Vins |
Thank You all for your responses. The bath is a neutral cyanide bath. I am extremely limited for space so a large holding tank is out of the question. This a wire plating line which has DI water dripping on the contacts on either side of each plating cell to prevent salt buildup, which insulates the wire from the contact. There are ten contact stations for the gold alone. The gold in this water is what I am trying to remove with the SBA resin. This rinse water does not pass through my drag out rinse station, it gets pumped through the resin, and then to cyanide destruct.
The drag out station pumps from a heated reservoir on the floor to the rinse cell and then drains back to the reservoir. I do have a Gold Bug operating successfully in the reservoir of the drag out station. The drag out is the first real rinse the wire sees after plating. I periodically bail out the reservoir, pass the water through the SBA resin, and send it to cyanide destruct, and refill the drag out with rinse water. After drag out there are two more rinses, the last being new DI water.
As there is a potential for significant gold in the water which bypasses the gold bug I will contact my gold bath vendor about the potential interference with IX. The Resin Tech lead is appreciated. I do not regenerate, the resin goes to refining after break through.
By the way, the first time I tried using a Gold Bug was on my silver cyanide line where I do not yet have a drag out, (no room). I was attempting to use it in a flow through tank with very low concentrations of silver, and no significant dwell time. It did not work. That is where I first started using IX to reclaim my silver.
Jerry Smith
- Bloomingdale NJ USA
We have a dry lake bed with large amount of water that holds precious metals in solution and wish the best way to recover same resin works good but expensive. Other suggestions are welcome. The lake is over 24 miles long and 500 feet deep with water us to three feet from surface.
Marks Morrison
industrial minerals - Windsor, CO
Save
This Page (why?) - Home - ©1995-2009 finishing.com
