-----Need electroplated Zn and Zn-Ni plates
I am a researcher and I need the following products for my comparison studies.
Zn and Zn-10wt.% Ni electroplated plated steel samples of 6" X 3" size (10-12 micron coating thickness on 0.8 mm thick steel). The quantity I need is 25 each. It will be great if I get samples that were prepared by using both acid and alkaline chemistry processes.
Can anyone tell me where I can get the above samples?
Researcher - Columbia, South Carolina, USA
Ed. note: Zinc-nickel alloy plating is done by proprietary rather than generic processes, Prabhu, so I suggest you contact the vendors and ask if their plating development labs can provide the samples. I think you will find that no single vendor offers both acid and alkaline processes so that you will need to contact two vendors.
