HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 41005
Chemical used to etch Ultem for POP
++++++Hi,
I would like to know what chemical substances is best used for the adhesion process for etching on Ultem 2110 platic for the EMI plating. The problem I am facing now is that the current chemical I am using is eating up the plasic surface of not more that 0.02 mm per surface. Please assist.
Injection Molder - Singapore
And what chemical is that that are you using, Sham. And at what operating conditions that is causing this problem? Thanks.
First of two simultaneous responses -- ++++++
I am using a compound mixture of Sulphuric acid and Chromic Acid on this etching process at 10 mins time cycle and I have also tried time cycles of 1 min ~ 30 mins. The amount of surface being eaten up by the chemical is still the same, maximum of 0.02 mm. From what I have studied is that EMI or Electroless plating process is a process in which tin layer of plating substances is added to the existing parts. Not eating up the surface...
Sham- Singapore
Second of two simultaneous responses -- ++++++
Adding to Ted's advise, Ultem is a registered trademark from GE. Maybe you should ask them. They know their product and how to process it, and you are the customer.
I see an on-line brochure for Ultem at http://www.plastoplan.com/download/ge_plastics_pdf_downloads/gep_Ultem%20Product%20Guide.pdf which says a special permanganate etch must be used (rather than the chromic-sulphuric etch which is normally used on ABS plastics). The brochure also notes the importance of using EPR (plating grade) Ultem rather than the standard grade. Good luck.
