Letter 4084
Stainless steel brown oxide removal?
I am restoring jet turbine engines for display purposes. This involves cleaning of 316 and other high alloy stainless steels who has been subjected to high temperatures ( 600degC to 900degC ). Over time a very tenaciously brown oxide has formed. To remove the brown oxide by abrasive methods is considered impossible on these complicated and thin walled and sometimes plated components ( blasting is not an option for this reason ). Is there a simple brush-on or acid bath or simple electro chemical method for removing this oxide without going all the way to electro polishing?
Eirik Karlsen   - Norway
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
