Letter 4062
Nitric Acid?
Can anyone tell me why a nitric acid bath is nessessary in the alluminum anodizing process?
chris - hampton va
It is not "necessary", it is a readily available cheap desmut chemical. Proprietary desmut/deoxidize chemicals are available, but at a higher cost. Most of them work better because they do two functions.
Probably the most effective deoxidize desmut is a mixture of sulfuric/nitric/ammonium biflouride. Effective, but slightly nasty.
James Watts - FL
What mixture ratio do you mix -mixture of sulfuric/nitric/ammonium biflouride- to make the desmutter and deoxidizer and where is the best place to buy these chemicals?
Roy Clarkson
- Rock Hill, SC, USA
It's best to buy a proprietary desmutter from an aluminum pretreatment specialist like Chemetall-Oakite, Macdermid, Nalco, Southern Industrial Chemicals, or U.S. Specialty Chemical.
finishing.com
Brick, NJ
Dear Reader: please choose what you want to do.
I want to post a question on a different subject.
I want to answer or follow-up on this question publicly
