Letter 4060
Blistering after 2nd layer of
Electroless Nickel
HELLO,I AM HAVING PROBLEM WITH BLISTERS IN THE CAVITY OF THE PARTS
AFTER PUTTING 100 MICROINCH OF ELECTROLESS NI. I TRIED TO PLATE IT
TWICE WITH SINTER IN BETWEEN TO SLOW THE NI DEPOSIT BUT I AM STILL
GETTING BLISTER AFTER 2ND PLATE. ANY HELP OR ADVICE WILL BE GREATLY
APPRECIATED.
THANX IN ADVANCE.
A LITTLE INFO:
- MATERIAL IS COPPER TUNGSTEN
NOLI BERLING
- San Diego, California
please help! our customer is not happy with the rough finish on
the parts due to sandblasting.
we tried baking soda blast but we are getting blister after 2nd
E'less. is there any other process that we can use to eliminate
sandblasting without blistering the parts? or is there any
sandblasting media that does not leave a rough finish that are easy
to clean?
material is copper tungsten
process
1 e'less
2 sinter
3 sandblast
4 e'less
5 electrolytic
6 sinter
spec calls for 100 microinch of ni with electrolytic ni on top.
NOLI BERLING
Tungsten Carbide is difficult to plate on. You need special
pretreatment for that.
Thick EN should also be a special EN. Not all EN processes can
plate thick deposits. Consult your supplier.
I am not familiar with the sintering that you mentioned but you
cannot plate EN on EN without electrolytic activation in between as
it will peel off.
Sara
Michaeli
chemical process supplier
Israel
