![]() Cycles thru suppliers. |
Letter 4059
Dave Wichern |
Hi Gordon ,
there are a multitude of products out there that will reclaim the Zinc from your solution , However , having had some experience in using several of them , the one I find easiest to use is the BEWT cell , these are sold and marketed in the USA although of UK origin.
How much is "Large Quantities" , is it as a Batch or is it constant flow ? There are several systems for sale second hand look in both Metal Finishing & Plating and Surface Finishing, they both have excellent Used Equipment Adds
regards
John Tenison - Woods
- Victoria Australia
I concur with the advice of John Tenison-Woods. With this addition: You may be able to purchase a Retec Cell. That is a tank with many alternating anodes and cathodes in which low amperage DC current is passed. The cathodes will be plated with the zinc very slowly and should be stripped periodically. This is an alternative to the BEWT and both are quite good.
Ed Budman
- Pennsylvania
Hi. Please see this web site's Used & Surplus section, where 10 major used equipment dealers list their offerings, or our Environmental products section. Good luck.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
