(Banner at right
cycles thru suppliers of
thickness measuring instruments)
Letter 4030
Measurement of copper thickness
I'm looking for a supplier of instruments that can measure the thickness of copper plated onto plastic connectors. Typical size range is 15 mm to 50 mm inside dia. Copper thickness range is 0.5 to 25.0 microns. Thank you
David Benson
Raychem Ltd - Swindon, England
Hey David,
The thickness of the copper and the physical size of your part present no problems for the standard methods: X-ray fluorescence, beta backscatter, or eddy current. But, I noticed you said inside dia. and for the most part the probes for these methods need to have an open pathway (straight line or be perpendicular to the surface) to your part. You might have to be destructive and open the part up to get a good reading. Sometimes you can process a sample along with the parts and compare the sample thickness to the parts and control your thickness indirectly. Regards,
Fred Mueller, CEF
- Royersford, PA
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
