Letter 4020
Thin films of gold or silver on fused
silica
To the members, I have a pressing requirement to deposit very thin
gold or silver films onto fused silica surfaces. Are there any
techniques you can use to do this. In particular I need to deposit
gold or silver (50-60 microns thick) without using a thick adhesion
layer. If any of your companies are interested in fabricating this
coating I would be delighted to hear from you.
Dr John Quinn
Dublin City University - Dublin
We have different concepts of 'very thin', Dr. Quinn. 50-60
microns is exceptionally thick for gold plating, and I think it's
been years since a jewelry plater or electronics supplier applied
gold that heavy. Is there a typo in your inquiry?
finishing.com - Brick, NJ
The inquiry I mailed did possess a typo and should have read as
follows.
I have a pressing requirement to deposit very thin gold or silver
films onto fused silica surfaces (10 mm length of stripped declad
optical fibre). Are there any solution phase electroless techniques
one can use to do this. In particular I need to deposit gold or
silver (40-60 nm thick) without using a thick adhesion layer. If any
of your companies are interested in fabricating this coating I would
Dr John Quinn
- Dublin City University -
Dublin
March 1, 2009
Hi, again. PVD processes sound more promising for such a thin film
on a non-conductive substrate. Still you should be able to do "two
part silvering" (simultaneous spray of silver nitrate and a reducing
agent) on a spin table, and gold plate it if you wish. Good luck.
finishing.com
Brick, New Jersey
