Letter 4016
Looking for material to protect clear plastic from abrasion/wear
Looking for a coating material to protect clear plastic from abrasion. Same material used to protect eyewear could work. This material is called ? siloxane? Anyone here of this material? If not please what is the materials used to coat eyewear (plastic lenses) from abrasion? Looking for a company to sell the materials for in-house use on my products.
John Grassi
- Cleveland Ohio
A UV curable hard coat would work for your application. They are used to coat lens and are typically urethane based. They can be formulated to give a excellent abrasion resistance, aging and adhesion for most plastics.
Paul Snowwhite
Milwaukee, WI
You are referring to polysiloxanes, which are very tough abrasion resistant materials with outstanding weathering resistance. I am sure there are many resin/polymer suppliers in the US who could help you.
Graeme Hill
- United Kingdom
First of two simultaneous responses-- .
UV Curable Lacquer would be an excellent choice. Resin type depends on type of plastic coated.
Les Trinity
- Middlesex, New Jersey
Second of two simultaneous responses-- .
JOHN, YOU MUST USE HARDCOATING OF GENERAL ELECTRIC. IN SOME CASES YOU NEED A PRIMER 401 AND THEN A HARDCOAT 4000.I wish you success.
jan rijn
- GOES, HOLLAND
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
