Letter 4011
Small Dia Chrome plated hollow
We are looking to find a source for the following.
Hard Chrome Plated Bar Base material s45c or similar. Outside Diameter 10 mm with a 3 or 4 mm Hole
Paul Kelly - Global Metals - Brisbane Australia
I'm not sure your description is clear enough. Are you describing heavy walled round mechanical tubing? If so, how long are the lengths? Does the I.D. need plating? How about the ends?
finishing.com
Brick, NJ
It sounds like your are looking for hard chrome plated .0005" thick bar stock with a 10mm OD and a 4mm ID. You will not find this on the shelf. Depending on the quantity you may special order the OD size chrome plated from the mill, but, you will also have to machine and or grind the ID. Length is critical to methods and cost.
Stephen C. Ward - Canada
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject
This letter is within a monitored forum, very much "alive" here in 2008. If you spot any broken links or obsolete info, please advise!
