(Cycles thru suppliers)
Letter 4008
Plating leaves/cones etc
I came across the 'finishing' site, whilst trying to find out the best way to plate organic materials.
Basically, I am trying to electroplate leaves and cones with a thick layer of copper, followed by a 24ct gold finish. I have set up a few trial experiments, but as yet have been very unsuccessful. I have tried a copper sulfate/water mix for the electrolyte and a piece of copper plate for the anode... but since reading more on the subject I have found that I may need to add some sulfuric acid to the bath. Also I am unsure about the anode. Does it need to be a special grade of copper?
The gold bath that I have, is just a pre-mixed salt, which I purchased from a jewellery supplies company, so I guess that should be okay. I have also a good dc. Supply unit (laboratory spec), so I have good control in that area.
The first few trials have resulted in crystallized or nodulised looking surfaces (copper), and when the gold plate is applied, it looks even worse. Dark, stained etc.
Could you please tell me where I might find out information and guidance on this subject?
Yours hopefully
K Weet
Kevin Weet
- Nottingham UK
Have you consulted our FAQ on this subject yet, Kevin?
How are you sealing the objects? How are you silvering/graphiting/metallizing them before copper plating? Yes, you probably need sulfuric acid in the copper sulphate--see our "must have" books for some basic starting points for copper plating. You probably also need organic brighteners/levelling agents, and frankly you probably won't get far without switching to proprietary plating processes.
You also should have nickel plating between the copper and gold if you wish longevity, since the gold and copper will gradually diffuse together. Good luck.
Ted Mooney, P.E. - finishing.com - Brick, NJ
I have came accross your article and I WILL BE ABLE TO HELP YOU golden roses, leaves, pine cones, and other ornament items.
REGARDS,
Norman Miranda
- Los Angeles, CA, USA
Ed. note: If you are offering free technical advice, Mr. Miranda, you're on exactly the right page, so start any time. But if you're trying to sell a product or know-how, please do it from a Products & Services directory listing instead.
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer this question publicly
I am a supporting advertiser and want to reach the inquirer privately.
