Letter 4005
Removing corrosion from chrome plating.
I have recently bought a vintage motorcycle. On some of the chrome parts there are small brownish corrosion marks visible. Could anyone please tell me which is the best way of removing these marks without damaging the chrome plating or without having to re-plate the part?
Joshua Kruger
- South Africa
Josh,
My best experience with antique bicycles was Naval Jelly [link is to product info at Amazon] and a lot of elbow grease. Make sure that you wax the parts really well, and keep them dry and waxed all the time. This worked for me on small spots and stains.
Once corrosion has penetrated through the chrome plating "film" it will be a constant headache. Truly the best solution is to replate the parts, but the procedure outlined above will handle the problem temporarily.
I might be tempted to try a metal prep type product to reduce some of the labor. You can get this material at automotive body shops - some even advertise that they convert the rust to an inert compound. I would try this on a non-visible area first though.
Good luck
Mark Atterbury
- Lincoln NE USA
I have a old vintage motorcycle and I put lacquer thinner [link is to product info at Amazon] and scrub then wax and sand lightly then wipe it off with Simple Green [link is to product info at Amazon].
Kyle Hentzen
- Haslet, Texas
The kind of corrosion in chromed metals are treated by cleaning well all parts of dark points, which are the instable parts, and after is well dried you must use a passivation film, like clear varnish. If it would be a museum piece you should remove the stains under the magnifier.
Best luck,
Rodrigo Bettencourt da Câmara
- Lisbon, Portugal
Dear Reader: please choose what you want to do.
I want to post a question or inquiry of my own.
I want to answer or follow-up on this question publicly
I am a supporting advertiser and want to reach the inquirer privately.
