Letter 40086
Cleaning filter cloth in line with 2% HCL
Solution [Texas]
March 28, 2006
Can you clean your filter press in-line (re-circulate
through press for x amount of time) with 2% HCL solution.
Larry Dilda
- Dallas, Texas, USA
March 30, 2006
Generally, yes. But pack a lunch. 2% is going to take a
long time. We found by accident that you can get nearly the
same result (if filtering metal hydroxides from waste
treatment) by thoroughly drying the cloth using a fan over a
weekend. Works like new on Monday. If the cloth is old and
fuzzy it should be replaced.
Paul Morkovsky
- Shiner, Texas, USA
March 31, 2006
Good Idea!!!! I will definitely try this trick this
weekend.. Makes perfect sense.
April 27, 2006
Larry
For what its' worth...
We have been experiencing problems with our filter press. We
precipitate chrome and zinc and run it through our filter press. The
cloths are 2+ years old. Previously, they were replaced after a year
when 'problems' arose. Our symptoms included- the press not filling
completely before our diaphragm pump stalled out; and after blowing
down, there was still considerable moisture in the cake.
We had tried mechanically cleaning the cloth with a siphon
gun/aspirator and had minimal sucess. Then we tried a high pressure
washer (car wash style). Our unit had a max output of 1300 psi and we
throttled the nozzle back to achieve a 3-4" spray pattern at a
distance of 3-4" from the nozzle tip. We started with a gun distance
of about 8-10" from the cloth and continously moved the spray across
the cloth. After several paths across the surface we could see the
white of the cloth. We continued until most visible signs of residue
were removed.
Upon re-install, they worked like brand new.
We left the clothes in the plate while cleaning, and would advise
starting at a conservative distance when spraying and work closer as
needed.
As mentioned earlier, drying the clothes out between uses helps a
lot.
Willie Alexander
- Colorado Springs, CO
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- I want to post a new
question or inquiry of my own on
a different subject.
