Letter 40029
What chemical to use for Titanium Etch [Maryland]
March 23, 2006
I am looking for an etchant that will remove a one micron layer of Titanium film without any effect on the gold layer under the titanium.
Any suggestions?
Can one explain the chemistry of the etching process?
Anil Dholakia
Electronics device developer - Jessup, Maryland
March 24, 2006
Dear Anil,
Try 0.5% HF solution. (Take necessary safety precaution). If your Ti layer has a thick oxide layer it will be while, but once the oxide layer is gone the Ti layer just crumbles you can see the H2 bubbling from the solution.
regards,
Karthik Thambidurai
- Austin, TX
June 22, 2006
You can try HF with various concentration. Since you only want to etch 1 micron, start from the low side. Plus, you can add CrO3 or HNO3 to HF. I heard acetic acid also ethces
Ti, you can give it a try.
Yi-Chung Su
metal processing - Taiwan
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
