HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 40014
How to get platinum coating on molybdenum metal
++++++We wish to obtain a coating of platinum or Pt-Rh alloy on cylinders made of molybdenum metal. The parts will be exposed temperature of 1600 - 1650 degree C and will also come in contact with molten slags, fluxes and glasses. The components are to be used for measurement of high temperature viscosity of melts. Is it possible to have electrolytic deposition of platinum or Pt-Rh alloy, or deposition from some molten salt bath?
Somnath BasuSteelmaking and Continuous Casting Research Group - Jamshedpur, INDIA
March 4, 2011
Hello, Somnath. Yes, platinum can be electroplated. Rhodium can be as well -- but I am not sure if a practical Pt-Rh alloy bath exists. Are you sure that platinized titanium would not fill your needs, as this is a well developed and rather commonplace material? Good luck.
