Letter 40007
Seeking Plating Shop for Sculpture
I need a plating shop (in Leeds, England) that would be willing to plate onto a sculpture and also advise in what would be the best material for creating the sculpture in, in order to get the best finish from the copper plating.
Victoria Rlast name deleted
Sculptor - Leeds, West Yorkshire, England
August 31, 2008
Hi, Victoria. Hopefully a supporting advertiser contacted you in private to offer their services. Metal is easily the best substrate for plating onto, but just about any substrate can be plated -- although the durability may be a problem, especially if the sculpture is outside.
For something unique, you could consider plating onto wax, then melting the wax away for a hollow sculpture (maybe you've seen hollow gold earrings? But I would not pick a substrate (other than metal) until you've located a shop that can work with it. Good luck!
finishing.com
Brick, New Jersey
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
