Powdercoating a vintage cast iron kitchen sink
Q. I am a homeowner remodeling a 1919 craftsman home. I'd like to know if powdercoating my vintage kitchen sink/drainboard would be an appropriate solution. It is etched and has some porcelain chips, but fits the space and age of my home. Would the powdercoat finish be appropriate for the hard wear a kitchen sink would get?
Dana Gronemyer
homeowner - Coquille, Oregon, USA
A. I had this done. It was a lot of work to chip off the old porcelain and they used a blowtorch too. had the sink about a month--so far so good. Cost $500 to refinish in Los Angeles.
Caroline Collins
- San Pedro, California, USA
June 11, 2009
Q. Hello Caroline,
How has your sink held up? We are thinking of doing the same.
Albert
Albert Reano
- Los Angeles California USA
March 10, 2011
A. It actually hasn't held up very well. It's got hairline cracks, and the bottom of the basin eroded through use and is usually stained back, and can't be cleaned.
It could be that they did a bad job, but I know they had trouble related to the thickness of the cast iron. Apparently that makes it harder to get the powdercoat to adhere.
I do have a lime green sink, and that's a win, but don't look in the basin.
Caroline Collins [returning]
- San Pedro, California USA
March 18, 2011
A. No one should consider refinished kitchen sinks to actually use in every-day kitchens. Porcelain sinks are furnace fired ceramic glass porcelain. Refinished sinks are painted, yes, even powder coated ones are simply dry paint melted onto the surface at just over 300 °F. It will never last. Try to buy a used sink in good or useable condition. If the basin is worn thru to the cast iron, put a rubber mat in the basin to cover it up. I see Albert looking to refinish. I suggest that he lives with the existing finish which is rougher than some. Or get a sink that has a better finish.
I would suggest that everyone avoid a refinished sink.
Ken [surname deleted for privacy by Editor]
antique kitchen supplies - Gardner, Massachusetts, USA
May 21, 2011
Will powder coating a kitchen sink restore the porcelain look?
Q. Can powder coat be used refinish the glaze on an antique kitchen sink?
Norman F. Peschke
maintence - Bloomingdale, Indiana, USA
A. Powder coating it can make it look good if it's done right, but if it's going to be used, you should restore it properly.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
A. Hi. As Ken notes above, porcelain is not paint or anything like paint -- it is much more like a layer of white glass or china melted onto the cast iron at glass melting temperatures. Powder coating is very thin melted plastic, and neither paint nor powder coating offers anything approaching the durability of porcelain.
Re-porcelaining services might exist, but we're not aware of any. Note that "porcelain enamel" or "porcelain paints" are not like melted glass, they are more like sand paint -- paint with ceramic dust mixed into it.
Q. Can you powder coat the outside of a porcelain tub and bake it at 400 degrees and not harm the porcelain on the inside?
Chandler Eidson
- Senoia, Georgia
August 8, 2016
A. Hi Chandler. I don't actually know, but unless you find someone who has done it successfully and repeatedly, I wouldn't risk it. Paint is not terribly different from powder coating in end result, so I'd just paint it.
August 2016
