HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 38456
Silver plating over Aluminum 6061
Hi All
Currently we are working on an RF amplifier which has an aluminum casing and we need to plate the casing by some means to be able to solder components onto the casing. From a local plating shop we plated some sample parts. The samples we plated first copper
(Mil-C-14550 [link is to spec at TechStreet] B) and then silver (QQ-S-365 [link is to spec at TechStreet]). But the silver plating peeled off when we removed masking tapes used during paint.
Could anyone suggest us another way of plating or where did we go wrong in our case ?
- Ankara, TURKEY
If the copper peeled off, then the parent metal either was not properly cleaned or properly activated (or both). If the silver peeled off of the copper, then the surface of the copper was the choice above or it was bright copper and had too much brightener. - Navarre, Florida +++++ If you want any help on this you must give details about the plating process, preplate cycle etc.
+++++ MIL-C-14550 B and QQ-S-365 have adhesion requirements
(identical tests) which the plating seems to have failed. But, did you bake the paint at a temperature above 149 C
(300 F)? QQ-S-365D, Paragraph 3.3.5 says higher temperatures weaken the adhesion of silver to copper. A barrier layer of nickel is required for long term use at higher temperatures. Do adhesion tests as-plated and after baking (if applicable).
Thanks for all the comments
The paint was cured around 60 C for one hour. I don't assume this created the problem. However we will also solder components onto this part by using vapor phase process, during which the parts will be exposed to temperatures above 200 C. I think we should use Nickel undercoat.
- Ankara, TURKEY
I use silver plating all the time for microwave RF housings that need to be solderable... We specify a Sodium Zincate cleaning process followed by a copper underplate and then silver... It's extremely rare (almost never) that we encounter any peeling of the plating... I suspect you are not using a qualified or experienced plating vendor... Bob Diamond- Hauppauge, New York |
Hi Again
In our second try, we first plated aluminum case with Nickel and then with Silver. The coating is mechanically fine, also it solders very well. My only concern is about thermal stress. Nickel is a brittle material, could it cause thermal cracking problem after a number of thermal cycles?
- Ankara, TURKEY
Hi there.
June 25, 2008
We would like know if plating aluminum with silver passivation is better or silver coating with gold flash is better to improve conductivity? which of the two processes are better in terms of durability and cost.
g.r.hathwarisro - bangalore ,India
July 1, 2008
Hi, G.R.. Silver plating with a gold flash would be a far more reliable and durable contact surface than passivation, but much more expensive. Regards,
February 17, 2009
We have a silver plating shop for silver plating on wrought & cast aluminium. Precleaning & undercoat are the important process to prevent peel off.
HEMANT SHAHswitchgear industry - Vadodara, INDIA
