Vacuum Metallizing of Paper?
Hello Everyone!
Has anyone out there had any experience of vacuum metallizing paper substrates?
I am interested in knowing which papers give the best finish, and what are the critical requirements of the paper.
The sort of details which would be helpful would be: What should the moisture content be? Kaolin or carbonate in the coating? What particle size for the pigment? What is the best latex to use / avoid? What surface or volume resistivity values for best performance?
I would be very grateful if anyone could advise me as to where I might get answers to these, as I am keen to understand the demands of the process.
Yours sincerely
David Owen
- UK
We are also interested in vacuum coatings on paper.
Did you receive any answer?
We are looking for a research project in this field.
Best regards
Vasco Teixeira
University of Minho - Braga, PORTUGAL
Paper metallizing systems are commercially available for at least a decade. Sheldahl in Northfield, MN, has done some of the pioneering work in the 1970s and 1980s, and is known to sell such systems. There are others but I do not recall the names.
Mandar Sunthankar
- Fort Collins, Colorado
Paper metallizing is currently done on a large scale commercial basis in South Arica, whereby we supply the primer and topcoat (water-based)
Marc Black
- Durban, KZN, South Africa
July 14, 2009
