Flash rusting after iron phosphating
Q. The steel parts we are treating with iron phosphate are rusting almost instantly. I understand that there is an aqueous rust inhibitor available. Where can I purchase it in New Mexico? -- or anywhere?
Jerry jaksha
Rio Rancho, New Mexico
"Phosphating of Metals"
by Werner Rausch
phos_rausch1991
"Preparation of Metals for painting"
by Samuel Spring
phos_spring1966_rare
A. Jerry whatever chemical supplier you are buying the iron phosphate from will have a "sealer" to purchase from them. It can be chrome or non-chrome. If chrome-based, waste treatment will be required.
You should be buying the iron phosphate from a company that can aid you in your process. The sealer neutralizes the action of iron phosphate.
Chemical suppliers are located in Denver, Phoenix, Los Angeles, etc.
Bill Hemp
tech svc. w/ chemical supplier - Grand Rapids, Michigan
A. You may consider using a "rust converter on eBay or Amazon [affil link] " instead of a rust inhibitor. rust converter on eBay or Amazon [affil link] s are especially useful for flash rust after passivation or abrasive blasting. I have been using a waterbase type for several Utility Co. applications for the past two years with good success. The one we use is manufactured in Texas. There have been some applications that have required some modification in formulation and they've been cooperative in those efforts for me.
Pete Bagley
- Reno, Nevada
A. Hi, Jerry,
If "rust" occurs just after iron phosphatizing, it is caused by improper operation of the iron phosphatizing. You might contact your chemical vendor to ask proper parameters to control the bath. Regards, Jun
Jun Q. Zhang
- Cincinnati, Ohio
A. RE: RUSTING WITH YOUR IRON PHOSPHATE
THERE ARE IRON PHOSPHATES WITH BUILT IN CORROSION PREVENTIVES AVAILABLE. THESE IRON PHOSPHATES WILL PREVENT RUSTING DURING AND AFTER PROCESSING. IF THE PRODUCT TREATED IS NOT TOTALLY CLEAN OR IF THERE IS EXCESSIVE LINE STOPPAGES, RUSTING MAY STILL OCCUR. THIS PROBLEM SHOULD BE EASILY SOLVED BY A GOOD CHEMICAL SUPPLIER.
RICH PODOLSKI
CHEMICALs & ACCESSORIES - LINCOLNSHIRE, Illinois
A. As Jun and Rich said, a healthy Iron Phosphate coating will not rust for several days. Flash rusting has several possible causes; low pH in the phosphate tank, drying between stages, dirty rinses, too low pH in the final rinse, dirty rinses, low phosphate coating weight, and finally... dirty rinses. I would first make sure the pH in the phosphating stage is at the upper end of its operating range, make sure the rinses are clean, then make sure the nozzles are spraying. By that time your chemical vendor should be on site to give you more guidance.
Jeff Watson
Jeff Watson
- Pearland, Texas
A. Dear Jerry
Don't let our honorable persons who answered you mislead you. Your phosphate can be OK and still rust after a few hours because Iron Phosphate coating is not intended to protect the metal without subsequent paint coating. Enough that the humidity in your plant a little bit high, then you will have rust on your Iron Phosphate Coating.
My suggestions are as following:
a. Don't leave the parts unpainted for a long time; plan your work that the paint will be applied immediately after Iron Phosphating .
b. In case that my first suggestion is not achievable, don't rinse the phosphate coating -- leave the coating unrinsed until painting time ,then rinse and dry the parts just before painting.
c. Chromate sealer can help solve the problem but not completely.
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
A. Not knowing the specifics of your operation (Salt Spray, humidity, immersion tests, etc.) and assuming you are looking for good adhesion properties only, I would recommend an Amine based inhibitor in the final stage of your wash system. This type of product is normally used at very low dosage rates (.5%-1% b/v) at ambient temperatures and very rarely interferes with the adhesion of your specific top coat (Liquid or powder).
Acidic final seal rinses are also adequate for some flash rust protection, but are normally less economical to use than the amine based products. I would suggest however, that you make sure the Iron Phosphate solution you are currently using is within it's recommended parameters (pH, temperature, concentration and time) so as to insure a uniform and complete conversion coating on the part surface.
Scott Winston
- Germantown, Tennessee
Q. Dear Mr.Scott Winston
Thank you for the suggestion to use amine based inhibitor in Iron phosphate chemicals. I shall be highly thankful to you if you could kindly write the particulars Full chemicals name of the "AMINE BASED INHIBITOR"
Thanks for your co operation.
Mahesh J Shah
- SURAT, Gujarat, INDIA
August 27, 2008
Ed. note: No problem with posting further non-proprietary info re. 'amine based inhibitor', but we don't post recommendations of brands or sources (why?)
A. Hello. When using iron phosphate (say 3-in-1, i.e., degreasing, derusting and phosphating), the treated component should be dried, then wiped with a dry cloth, and painted as soon as possible. If left unpainted the component could in the course of hours start getting rusted. Another process called zinc phosphate applied to mild steel components in a seven tank process could help in keeping the components rust free for days without painting. Further details can be furnished.
harish chitkara
synthetic polymers - India
A. To prevent the flash rust you have to modify the phosphating formulation and add aromatic carboxilic acid such as benzoic acid 2.5 - 3 %
and try to be care about all the phosphating parameters as Mr. Jeff said before
Ahmed Fouad Serag Eldin
Ein Shams - Cairo - Egypt
Q. My question is: Would Fe Phos be suitable for S.S. If so what treatment sequence, if any in particular? Is there any reference material that I can study? Thank you. Ed
Ed Darrow
- Indianapolis Indiana
Q. Will phosphating protect the tapped threads of the metal parts after powdercoating, since threads are usually masked from powder paint?
Randy Caraon
- Rosario, Cavite, Philippines
April 12, 2012
A. Hi Randy.
Although phosphatizing will provide only limited protection, depending on how well oiled the tapped holes are, it sounds like the right general idea. But zinc phosphating or ideally manganese phosphating, would be much better for this than iron phosphating.
April 15, 2012
Q. I have two dipping tanks in my shop. One is heated to 60 degree (iron phosphate/degrease)
and only one unheated rinse.
The substrates get out from the last rinse, and after 10 minutes get rust/yellow color; the second day get rusted.
How can I deal with my problem?
osama rashad
- egypt
November 20, 2013
A. Hi Osama. A 3-step iron phosphating process is the absolute minimum pretreatment and, as you read above, is still open to many problems. I would say you can't properly pretreat in two steps, so the first thing you need is a 3rd tank. Good luck.
November 2013
Q. We use a "room temperature" iron phosphate product at low concentration for powder coating pre-treatment. We vary the temperature [up to 120 °F] and conveyor line speed [impingement] depending on cleanliness and type of steel. Our customers only require minimal salt spray adhesion. Parts are mostly water-break free. We are seeing some flash rust streaking post dry-off oven. I used a "rust preventative" in the final tank rinse many years ago. The chemical was dyed yellow green and could be seen in the tank. The 1000 gallon tank was dumped and recharged every day. No flash rust. Is such a chemical still available?
tom spear
- racine, wisconsin, usa
January 14, 2019
January 16, 2019
A. Hi Tom,
The specifications we use for manganese phosphating tell us to dip the parts in a chromic acid rinse at 350 mg/l with a temperature above 65 °C for 7 mins.
I have found that not doing this results in salt spray failure, but always a pass after 90 mins exposure if I do do it.
The chromate reacts with iron that is still exposed to the atmosphere after the phosphating, effectively sealing the part.
We keep the pH between 3 and 6, and dump it weekly.
And yes the tank will have a yellow green colour to it.
Best regards
Mark
Mark Lees
- Wintery rock in the Irish Sea
A. Tom,
Reach out to your chemical vendor for a water based rust inhibitor. They are typically nitrite or amine based, make up around 5%, and are commonly dyed bright colors. You'll want to discuss your entire operation with them when picking amine or nitrites to make sure you don't introduce nitrosamines to your process. There are pros and cons to each.
Per Mark's comment, a chromic rinse is required on manganese phosphate to do MIL-DTL-16232 [from DLA] and is definitely effective at increasing the salt spray resistance. Down side being the environmental concerns of brining chrome in house. You'll have to waste treat that or pay to haul off a lot of chrome rinse water.
Jameson Grout
- Agawam, Massachusetts USA
January 17, 2019
