letter 3915
- Hi, I was wondering if anyone knew of the process of antiquing mirrors to give it that brown-black smoky look. Any leads would be appreciated. Rob Bryant
- Hey Rob, The silvering (the chemical precipitation of silver) is bright and shine at first but will oxidize or tarnish if left unprotected. The early coatings used to protect the silver were a little hit or miss (the selection of the coating improved over time). So, the brown color is from the interaction between the coating, oxygen in the air, and the silver (and the precipitation method used) over time. Unless you have a lot of time to spare, say 50 years or so. You may need to work this problem backwards and treat the glass to get the color you are looking to get. Regards, Fred Mueller,
CEF
+ How do you "treat the glass" to get this antiqued look, smoky and with darkened sections. Anne Barton
++++ Hi Rob Hey! you ask the very question I was about to. We want to antique a mirror to put in our new bar here. Now the technique I recall being explained to me - but I have never tried - is to burn sulphur on the back side of the new mirror. I recall being told you lay the mirror down on say trestles - open air would be a good idea I expect - mirror side up. Underneath you place small dishes of sulphur (I don't know how far from the back of the mirror) and set them alight. Apparently the burning sulphur corrupts the backing. I am will to give it a go and will report my outcome. If you give it go, plse let us all know how it goes for you. Regards, Bruce Robinson |
I have nothing to contribute to the process but I am interested in learning how it is done. So if anyone tries the sulphur solution, please post the results.
Sunny Rogers
- Rhinebeck, New York
I have had great success with alcohol ink on the surface of mirrors to create a faux antique effect. It turned out great and the alcohol inks are easy to find, come in a lot of different colors, easy to work with, non toxic and are inexpensive.
aimee bishop
- Colorado springs, Colorado
Hi--just got on this site and want to share another site that provides info on how to antique (for grey, brown, clouds, blackened etc AND sells all the stuff to do it except for the paint thinner) They are called angelgilding and I'm going to order some of their stuff but want to try it out on small samples of mirror to get the technique down first. You can get small mirrors at Hobby Lobby for a few dollars.
Shaloria Taylor
Save
This Page (why?) - Home - privacy policy - ©1995-2010 finishing.com
