Corten Steel -- Q&A, Applications, Problems
Q. I work for a metal fabrication business, and we are bidding on building a bridge out of the Cor-Ten steel, I am looking to find the actual mill this material is processed from.
Not looking for a steel provider, but the actual steel mill.
Thanks in advance!
Jake Stanbery
- Lufkin Texas
January 9, 2024
Corten woman by Willemine van Laarhoven, thumb
Corten Woman by sculptor Willemine van Laarhoven
Q. If I sand blast corten steel prior to painting does that have an effect on the rust resistance of the corten steel?
Kim R Pelletier
- Plymouth Connecticut
July 2, 2024
A. Hi Kim,
No, Corten is not a coating, but a type of steel. Sandblasting will not change its nature.
But Corten is not actually "rust resistant" like stainless steel -- it rusts as quickly as other steel. The magic of Corten is that the rust adheres a bit better and is not as fluffy and hygroscopic ... so once it rusts, there is at least some 'sealing' towards slowing further rusting -- the drier the climate and the more salt-free, the better.
Will corten windows & doors survive salty sea air of Mauritius?
Q. I WOULD LIKE TO KNOW HOW TO TREAT CORTEN RUSTED STEEL. I ORDERED TO HAVE MY WINDOWS & DOORS WITH A LOCAL SUPPLIER, UNFORTUNATELY AFTER DELIVERY I REALISED THAT THE METAL USED IS SUPPOSED TO BECOME RUSTY IN SHORT PERIOD OF TIME AND IS NOT AESTHETIC. I WOULD BE GRATEFUL IF SOMEONE COULD HELP ME KNOW MORE ABOUT THIS METAL AND ITS INCONVENIENCE AND HOW TO TREAT IT. THANKING YOU IN ADVANCE FOR YOUR COLLABORATION.
BECHE BRUNO
- MAURITIUS (Indian Ocean)
A. Corten steel is a special steel used in architecture to give a pleasing (to some!) patina. The steel is designed to "weather" or "age" to give a coppery colour that will improve with time. It is resilient to many corrosive atmospheres. If you do not like it, I suggest you remove the patina and paint it with suitable paints.
A. I stumbled upon this website and found this question. Leave the Cor-ten steel alone. Let it patina. It is beautiful.
Dan O'Mara
- Minneapolis, Minnesota
Q It is a beautiful finish aesthetically. And I agree that it should be left alone.
Does anyone know the life cycle of this finish and do companies warranty it?
Joeey Poitevin
Joeey Poitevin
- Jackson, Mississippi
A. Sir;
1. The Corten steel in your case should not be used for windows or doors. Corten Steel in primary used for bridge frame and structure usage.
2. if you must use Corten Steel, you need to get a prepaint or coated type, check with US Steel Construction manufacture. If you leave your Corten steel window and door as it is, it is unsightly and the value of your property will be affected because appearance is important for property value. Also in addition, over a long period, it will just become a pack rust looking, some may find it okay but I can ensure that majority of regular folks will not agree with it.
3. Corten Steel has a very good tensile strength but is not recommended for any residential usage. Anyhow, no one say you have to.
4. You should treat the Corten steel with a VOC corrosion inhibitor on eBay or Amazon [affil link] . Select the one that will give you the finishing that you want. Normally, a good VOC corrosion inhibitor should give me a long term protection as well as a smooth finishing.
Danis P [surname deleted for privacy by Editor]
engineering service - Ontario, Canada
A. I am a student at FSU and have been working with Corten material during class. We have a Corten sculpture here on campus and it has a nice dark purple color. It looks black from a distance. the oxide layer will not degrade, our sculpture has been up since 1980 and it still looks great.
Kenneth C [surname deleted for privacy by Editor]
Ferris State University - Big Rapids, Michigan
Penetrol
penetrol
on eBay or Amazon
A. In a previous life I have priced work for an award winning architect named Sean Godsell, who regularly specifies Corten as an exterior cladding on the houses he designs (often in coastal environments). To accelerate the corrosion process he requests that "Penetrol" ⇨
be applied (commonly used as a paint thinner). It proves to be very successful. I also believe that the Corten can be later sealed for internal use, however I'm not certain of the appropriate paint to use.
David Down
construction - Melbourne, Australia
April 21, 2008
A. We are a window manufacturer that produces windows in Cor Ten steel among other materials. The engineer that says it should not be used for windows should know that it is very common in Europe where our system comes from. It is quite expensive about three time the cost of galvanized steel. Beauty is in the eyes of the beholder, I myself do not like the look but some do. It requires no maintenance.
Richard Sussman
- Port Washington, New York
July 9, 2009
A. We are a distributor of high end architectural windows. One of our products is available in Corten steel. The way we treat the finish is after fabrication it's allowed to weather for 2-3 weeks to develop the desired patina. The loose "dust" is then removed and a coat of wax sealer on eBay or Amazon [affil link] is hand applied giving it a very unique leather-like look. This finish lasts indefinitely. Corten if left alone will take 2-4 years to reach it's peak patina and then should remain in that state with very little change.
Bill Polinsky
steel window supplier - Bridgeport, Connecticut
July 16, 2009
A. Hi. "Corten" is a trademark of US Steel for "weathering steel", but US Steel only makes it in limited shapes anymore. When people speak of Corten, they usually just mean "weathering steel", which is described in ASTM A242 (Cor-ten A) and ASTM A588 (Cor-ten B).
I don't claim experience with weathering steels, but based on my reading I disagree a bit with some of the responses. Weathering steels are not resistant to salt air, both because the salt causes pitting, and because it is hygroscopic and the steel tends to stay wet, which prevents the proper patina from forming. What is beautiful and stable in Minneapolis, Jackson, and Big Rapids might be nothing but a rusty mess on an island in the Indian Ocean. Along with the many Corten successes, there have been spectacular failures; for example, Aloha Stadium in Honolulu has never stopped rusting and has required millions of dollars in rust treatments.
But because Corten's composition differs only slightly from standard hot or cold rolled steel (it is a low alloy), and from my reading, I would agree with Trevor & others and not anticipate any problem in waxing it or pretreating & painting it. Good luck!
SA Equivalent for Cor-ten A
Q. Does anyone know if there is an ASME or ASTM equivalent for the European material Cor-ten A?
Albert Verduyn
Boilermill - Holland
A. COR-TEN A is a U. S. Steel trademarked HSLA weathering steel with a minimum yield point of 50,000 psi and an atmospheric corrosion resistance 5 to 8 times that of carbon steel. Applicable standards are
ASTM A242 "Standard Specification for High-Strength Low-Alloy Structural Steel"
and
ASTM A606 "Standard Specification for Steel, Sheet and Strip, High-Strength, Low-Alloy, Hot-Rolled and Cold-Rolled, with Improved Atmospheric Corrosion Resistance".
Ken Vlach [deceased]
- Goleta, California
Corten for Ship Repair
Q. I work in ship repair. We need to weld double patch on corroded area of gas air heater water washing drain hood and basket casing. Can anybody help how economical if we use Corten steel? Roughly how much is Corten steel in USD per kg? Thanks
James Jimenez
A. COR-TEN IS GOOD.
While reading, I noticed that someone wanted information on price of Corten.
It is around 1350 USD/MT.
VIMAL JAIN
- India
October 9, 2010
Q. Is Corten Steel good for manufacturing boats? Is it good in water environment if painted?
Norman Parmley
student - New Bern, North Carolina
March 5, 2008
Q. Someone asked if it was OK for making boats. No answers yet. Has anyone any thoughts on this?
Stamford Stoddard
buying a 16 metre boat - Chichester West Sussex UK
May 19, 2011
Use on interiors: does it rub off?
Q. Hello, I am a builder and my architect has specified Corten steel for use above an interior fireplace and on the face of the hearth. Once installed the steel will not be subject to any moisture. I assume I should pre-rust the steel before installation to get the corroded look that is so attractive with Corten.
My questions are:
1. Will it corrode in a dry environment?
2. If I am to pre-rust it is there any treatment I should use on the steel to remove oils or other contaminants.
3. Should I use sea water to hasten the corrosion? I have actually tried a few samples using sea water and have had varying success, some with pretty good results, others that the corrosion is very spotty, as if something present on the surface was preventing the corrosion.
4. If I achieve the desired level of corrosion before installing the pieces, can I seal it to prevent people in the house from getting the rust on them or their clothes?
Mr. Courtney G [surname deleted for privacy by Editor]
construction - Santa Cruz, California
Q. Looking for the follow up on Mr. Courtney G's interior Corten questions. I too am building and we are using Corten to clad fireplace, hearth and surrounding wall. We are looking for help in areas of thickness used, mounting, and sealing so customer won't get it on themselves.
F Heathen
- Madison, Wisconsin
January 31, 2008
Q. Should Corten steel panels rust to the point that you can rub the color off easily?
Robert Vtinreo
installer - Watertown, Minnesota
February 12, 2008
A. Hi. The rust will brush off, and the customers will get it on themselves. I think it is may be more practical to paint the steel a nice rusty color if people will be touching it. Companies which supply Corten roofing also offer painted steel in very closely matching colors. Good luck.
A. If you have to paint it and want it to last, wire brush off the worst till you have reached an acceptable finish level, it does not need cleaning back to perfect, then paint with Hammerite Rust Cap on eBay or Amazon [affil link] , this is a bonding paint available in many colours.
it will last for years and should prevent further rusting.
Friends and I have used it for over 30 years and never found any problems, we have even used it to cover the bottoms of cars to delay salt corrosion, as our local authorities believe in very liberal applications of salt on our roads.
Peter Nixon
- Middlesbrough, UK
Ed. note: Rustgrip was engaged to repair Aloha Stadium in a similar manner in 2003. You can google those words for updates.
Q. Is it possible to stop weathered Corten from ending up on the clothes of the general public. Can it be sealed after weathering?
Tim Farrow
landscape architect - England
December 16, 2011
Permacoat Xtreme
sealer_permacoat
on eBay or Amazon
Masterclear
clearcoat_masterclear
A. Hi Tim. The rust will rub off. Clear coating or painting Corten should not be difficult, but a chain is only as strong as its weakest link; so, with the rust not tightly adherent to the substrate, the clear coat adhering to the rust may not be much help. I'd try a clearcoat that is designed really "wet" rust finishes, and hope for some bite through the rust and onto the steel.
A. The Corten steel finish can be coated using a water based coating Perma Coat ⇨
then finished coated with Master Clear from Modern Masters ⇨
I have seen this effect extensively used in Spain and Portugal.
neil cody
design - Vancouver, BC, Canada
January 30, 2009
Q. Want to use container to build a house project in Thailand Bangkok.
Want to protect Corten steel from rusting after I sandblast.
Jean Ferron
- Thailand
April 16, 2010
Does that come in Black?
Q. I am using Corten steel (6 mm thick), but would like to achieve a almost uniform black color for a special application. Does anyone knows any 'tricks' or procedures ?
thanks for any reply.
Michael P [surname deleted for privacy by Editor]
- Adelaide, South Australia
A. I work as a contractor and we have had rust stain problems with the Corten steel. I am not sure this helps with the original question, but we have used a "blued" metal with a clear powder coat finish to achieve a nice mottled, but rust free look. The "bluing" is done by hand, I believe it is the same chemical used to maintain gun barrels. (at least, that is where I first heard of it).
Colin Thompson
- Los Angeles, California
Ed. note: "Gun blue" and "black oxide" are actually the same process. Highly polished surfaces come out dark jewel blue, but matte surfaces come out black. Search the site for many threads about gun bluing / black oxide.
Q. Can anyone assist in what material should be used to clean spray paint (probably cellulose) graffiti off the face of CorTen steel cladding without damaging the surface.
Michael W [surname deleted for privacy by Editor]
architects - London, England
"Sustainable Landscape Construction: A Guide to Green Building Outdoors"
by Sorvig & Thompson
sustainable_landscape_construction
Q. All of my impressions of Corten is that once up it doesn't need to be maintained. I am using this material as part of entry sign for the community of San Pedro, California.
I am concerned with graffiti and general wear as it will be in a maritime climate.
I am a Landscape Architect with the City of Los Angeles, Recreation and Parks, Advance Planning.
Craig R [surname deleted for privacy by Editor]
Achieving even rusting
Q. Even rusting of weathered steel? I am creating an outdoor sculpture (about 2.2 m high x 2.5 m wide) of 6 mm thick weathered steel and need the surface to rust uniformly and quickly. I have only a couple of months to get it to a reasonably even surface, and there are laser cut outs in the steel. The sculpture will be installed outside. Any suggestions?
Chris Cathie
sculptor - New Zealand
April 3, 2008
Soda Blaster
soda_blaster
A. I AM BUILDING CUSTOM HOMES MADE OF CORTEN. WHAT WE HAVE FOUND TO GET THE WHOLE HOUSE TO RUST EQUALLY IS TO HAVE IT SODA BLASTED. IT IS LIKE SAND BLASTING, BUT USES A BAKING SODA TYPE MEDIUM. AS FOR THE INTERIOR WALL PANELS THERE IS A PRODUCT THAT DOES SEAL THE MATERIAL, BUT IT IS AN OIL BASED PRODUCT AND DOES TAKE A LONG TIME DRYING. IF YOU ARE IN NEED OF REMOVING PAINT OR GRAFFITI IS TO SODA BLAST IT ⇨
THE BLASTING WILL NOT ROUGHEN UP THE SURFACE.
CHRIS MILLER
STRUCTURAL STEEL FABRICATOR AND INSTALLER - PHOENIX, ARIZONA
A. Abrasive blasting is the way to go for an even rust finish.
I have found that the original rusting stage does produce staining but once this has been achieved the run off is minimal. The nature of corten, as I understand it, is that the oxidation layer becomes very dense and this protects the underlying material. There is not a continuation of oxidation into the material so there is no more oxides running off!
I love the dry dusty appearance of the corten and have never sealed it because I don't want to loose this. Is there any processes or materials that can seal the surface but leave the dry finish.
Q. From my reading of any material about corten I understand that a coastal situation is not recommended but as David Brown has stated above he has done this.
I am trying to convince a client at the moment that corten will be suitable for a balcony balustrading on a house right on the beach here in WA.
Can any body help me?
Rob McCulloch
- Perth, W.A. Australia
June 25, 2010
Q. After blasting the Corten steel surface is within no time black.
Is this copper, chrome or phosphor oxide which is left behind the surface and can we paint over this surface?
Erwin Nijman
inspector - Holland
March 10, 2010
