HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 37074
Can hot dip galvanizing warp a car frame?
Stock C-3 (1972) Corvette frame. Material 11 gauge mild steel. Constructed of upper and lower formed halves welded together. This is a stock 1972 Vette frame, not a custom fabricated tubular frame. Can hot dip galvanizing cause this frame to warp?
If yes, are there other galvanizing processes that could be safely used. I want to coat the inside also, if at all possible.
Than you so much!
Auto Hobbyist - Minneapolis, Minnesota, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
