finishing.com logo
    HOME / sitemapFAQsBOOKSHelp WantedsAdvertiseContact   you are here: Hotline/Forum => Letter 36139
Electroless nickel plating on brass per ASM 2404, class 2
I have brass parts that require electroless nickel plating for corrosion resistant. AMS2404 [link is to spec at TechStreet], class 2 requires post plating heat treatment for harden the deposit. Do I actually get better adhesion of nickel by specifying class 2? What are the advantages and disavantages between class 1 and class 2 EN on brass?
Norm Dang
Instrument Co. - Santa Ana, California, USA
Hardening electroless nickel coatings will severely reduce their corrosion resistance and may cause the coating to crack. However, it will improve adhesion.
Ron Duncan
- LaVergne, Tennessee
Ed. note:
It is our sad duty to alert the readers to the passing of Ron Duncan on Dec. 15, 2006. For those who would like to know more about him, a brief obituary opened Update No. 13 of our Metal Finishing Industry Update Podcast.
ANSWER, or ASK a related Q. POST an unrelated Q.See HOT Topics
disclaim
 seek
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2013 finishing.com     -    Privacy    -    Search
