-----Removing boron from wastewater
Most readers with boron treatment experience feel that ion exchange is the only reliable way to get boron to really low concentration, but it requires specialized resins with very little holding capacity and is very expensive.So reduction at the source, or pretreatment in some manner is usually recommended.
Thread 153/07 addresses Ion-exchange; the thread you are reading covers the other alternatives. Please forgive repetitiveness as we've assembled together a half-dozen formerly independent threads.
Probiotics
Q. I may have a problem with Boron as a result of periodic high concentrations of Borax. Boron seems to be a problem. I have a current metal hydroxide precip. system and the boron reduction is less than 25%. Need a reduction of 75% or more to attain a limit of <7ppm. I'm sure ionx will work but would like to investigate other active chemical methods that could be easily be incorporated into the existing precipitation process.
Thanks in advance --Rich--
Richard P. [surname deleted for privacy by Editor]Digital Analysis Corp. - Marcellus NY
A. We have had success with AMD using some probiotics in concentrations as low as 1-3 ppm. They run approx. $60. for 2.5 gallons. Would you like a sample? I have been testing these products in the lab so I have a little left over.
Sharon WetzelProBio
Need to reduce Boron in waste to <0.2 ppm
Q. Will a method work to remove levels of boron from 1.2 mg/L to <0.2 mg/L (our discharge criteria)?
Jamie K [surname deleted for privacy by Editor]Ontario, Canada
A. Hi Jamie.
Thread 153/07 seems to indicate that this may be possible with highly specialized ion-exchange resin, although it's capacity is very low, so you'll need to manufacture then landfill an awful lot of expensive and exotic specially polymers to achieve it.
Can anyone explain what justifies this expenditure of resources? I'm no medical expert or epidemiologist, but in a world with many natural waters not even approaching this low level, and it seeming to be far below even the level accepted as of negligible effect, what justifies this burden on sustainability? Thanks!
Q. We have up to 35 ppm in our waste water. Shall like to know more about a system. flow rate is 6m3/hr.
regards
karan
- new delhi, India
Q. I am a waste treatment operator in a job shop and I am looking for information on treatment for boron that comes from an aluminum cleaner. I am also looking for a good replacement for that cleaner (Waste treatment friendly). Any information would be appreciated.
John B. [surname deleted for privacy by Editor]Gold Tech Ind. - Tempe Arizona USA
Q. We are interested in a Boron removal process
Miguel N. [surname deleted for privacy by Editor]- U.N.S.J.(Fac. Ing.)-San Juan-Argentina
Q. I am interested in removing boron and boron compounds from a wastewater stream.
If anyone has any ideas I would appreciate hearing it, or if they can point me in the right direction it will also help.
Q. I am also looking for wastewater treatment technologies for the removal of boron ... any current literature? Any help greatly appreciated.
James P [surname deleted for privacy by Editor]- Hot springs, Arizona
Q. We have also been on a 4 month long search for cost effective boron removal from wastewater.
The raw wastewater contains varying amounts from 100-1100 mg/l of B (as borate we believe). Conventional treatment technologies (metal hydroxide precipitation) has brought the levels down consistently to 100 mg/l from 1100 and to 30 mg/l from 100.
Our goal is to reach levels below 4 mg/l consistently. The only technology which appears to work (thus far) is Ion Exchange. This technology is extremely expensive, and we have been researching other options.
The most recent attempt (reverse osmosis) has brought our levels down to 13 mg/l.
If you or anyone else has some ideas or success, please let me know.
Thank You.
- Plainville, Connecticut
Q. Still working on the Boron removal issue.
We have coordinated some efforts with the University of Hartford, and will have some results by the end of this year.
Mark E. Morgano, P.E. [returning]- Plainville, Connecticut USA
Thanks. We will be most happy to print here any non-commercial findings you or the good doctor from the University of Hartford release!
RO and Microfiltration
A. We are currently researching boron treatment. There appears to be some limited evidence that boron reduction (10 to 30% depending on the concentration - >10 mg/L and process) can be achieved in some conventional treatment plants. No reduction data for boric acid. Research is for a landfill with 10 to 15 mg/L boron levels. Treatment objective is less than 5 mg/L. At levels greater than 50% reduction, literature suggests a micro-filtration process.
John Stidwill- Ottawa, Ontario, Canada
A. If you're interested in high removal rates of Boron, the way to go is EDI (Electro deionization). Another option is to use two step R.O. which will leave you with 25% remaining in the feed (75% removal). Good luck and greetings from the Netherlands
Jorg Korver- the Netherlands
A. We are removing boron from wastewater, using an RO system operating with preconditioned effluent, it is on service since January with consistent results below 10 ppm
Rogèrio Toledo de Almeida- Guarulhos, Sao Paulo, Brazil
A. We are currently removing Boron from 200 ppm to 6 ppm by using crossflow microfiltration after chemical pretreatment.
Israel Garden- Haifa Israel
Q. I'm doing my thesis now. I need information about correlation between pH and Boron removal by using RO membrane. I would appreciate if anyone could help me.
Tan Ming C. [surname deleted for privacy by Editor]- Skudai,Johor Bahru, Malaysia
Q. I have the same questions. I just finished my PhD and I'm living in Turkey and in Eskisehir (the biggest Boron Ores Mines) and our old technology factories cause waste water problems. I wish to work on removing them using membranes. I'm open for all kind of suggestions
S. Eren O [surname deleted for privacy by Editor]Anadolu University - eskisehir, Turkey
A. Hello, I found on the internet some answers. You can change pH to
9 or higher to receive more borate ions. It gives more efficiency on Reverse osmosis membranes.
I hope that was helpful.
- Mikolow, Poland
January 17, 2008
Activated Carbon
A. I do research on removal boron from wastewater. I'm using RO and then use the sample after RO treatment, do the adsorption with activated carbon. The result so great ... less than 1 ppm boron.
Suriyati SalehUniversity Technology Malaysia - Johor, Malaysia
Zeolite / Bentonite
A. You might want to try filtration using zeolite medium. Or use bentonite clay chemicals. Results are very good.
Redzuan Razak- Shah Alam, Selangor, Malaysia
Chemical Precipitation
A. Boron compounds are reduced under high pH. Depending on the process and objectives, pH precipitation is likely indicated and advisable. There are some ion exchange compounds that can achieve the desired level, again subject to objectives.
For example: a zeolite process with caustic soda ⇦liquid caustic soda in bulk on
may raise the pH to 9.5 or 10. This may precipitate elemental boron by 60%. Complex boron or bound boron complexes may require a higher pH, and caustic soda may not be a suitable agent. If reductions at 98% level are required, suggest another agent to raise pH to 11, then design neutralization complex to suit (i.e. sulfuric acid or carbonization...subject to cost efficiency process selection).
Treatment of Boronated Waste Water using an RO Membrane
Q. In treatment of boronated waste water by using an RO membrane, what are the most important factors that should be considered? How does the pH factor influence the performance of the treatment (type of membrane that have been used is spiral wound)? pH will influence the concentration of the boron in the water. By theory, the treatment should be done in the pH condition that the boron concentration is minimized. When doing this filtration, what type of ion boron is the easiest to reject (ion boric acid or the complex ion of boron)?
For your information, the concentration of boron is analyzed with the HACH DR/2000 by Carmine method.
Chemical Engineering Pilot Plant (CEPP) - Johor, Malaysia
Q. We have up to 25 mg Boron/l in our wastewater (Raw material content of B2O3). Will a system or method work to remove Boron up to level <1 mg/l(our discharge criteria)
W.K. Tan- K.L. , Malaysia
Q. Whomever works on that subject (treatment of boronated waste waters using membranes), I have some questions. I finished my PhD 3 months ago and I decided to work on BORON subject. Cause as you know, Turkey is one of the biggest boron mineral ores underground. And our old technology factories cause some wastewater problems.
If anyone replies, I'll be appreciative.
- Eskisehir
Q. I am interested in boron removal from water, in particular from produced water. I am studying the feasibility of this by a electrochemical means.
G Pieruz- Manchester, England
Q. Sodium Borohydride used to tackle high carbonyl and high iodine value in our factory that is producing a fatty alcohol product. This traces of chemical end up as free Boron in our waste system that is causing us to find a solution for treatment. If possible I want to know also a low cost method of removal of this metal.
Karrin Rawing- Kuantan, Pahang, Malaysia
Q. We are looking for methods to remove 16 ppm of boron from industrial effluent (picture tube manufacturing). Please suggest methods.
Aparna [surname deleted for privacy by Editor]water and waste water treatment - Navi Mumbai, Maharashtra, India
Q. I am a student on attachment with a company which specializes in manufacturing and which has its own waste water treatment facility. We aim at reducing boron to less than 5 ppm. we plan to use chemical methods to treat the same. Currently we are using Aluminum sulphate, Polymer and Lime and though the results are good, high boron water greater than 15 ppm cannot be treated on its own. Thus we plan to use a new procedure which uses hydrogen peroxide and an 'Accelerator'.
What is an accelerator? could anyone please help me? also any other chemical solutions for a 90% reduction in boron by methods other than RO or any physical processes.
Avinash Chandramoulistudent - Singapore
Q. Waste water contains boron of 300 ppm should be removed effectively to less than 5 ppm. Would like to get suggestions.
Anbananthan n- Hyderabad, Andra pradesh, India
A. Your solution is by oxidizing with Electrolytic Catalytic Precipitation (ECP) removing method. In this method we will oxidize the metals by overdosing the wastewater with oxygen and electrolytic breaking of the molecules. The results are solid metal oxides and gases and water.
Damian Dinu- Constanta, ROMANIA
? What is the formula for that oxide of boron that you will be forming, Mr. Dinu? Is it B2O3? I was under the impression that this oxide dissolves in water, forming boric acid. What oxide of boron will efficiently precipitate please? Thanks.
Q. I need to find a way to treat our waste water ,there is 1000 mg/l b as boric acid, and the limits is 1 mg/l only, any one can help us ?
WANG CHUAN HSINENGINEERING CORP. - TAIWAN
A. It is difficult to remove boron from water. It is not significantly removed by conventional precipitation processes. There is a selective ion exchange resin that will remove boron to < 1 mg/L and concentrate the boron, but it has a low capacity and is expensive, and will still result in a waste solution that must be dealt with.
In situations like this, it is usually best to deal with the problem as close to the source as possible. Sometimes the best solution is to use a DI or an evaporative recycling system to recycle the water and to eliminate boron from the discharge. Like the selective ion exchange mentioned earlier, this may still result in a boron containing waste that must be hauled off-site for ultimate treatment and disposal.
Good luck in finding the best solution.
A. We have significant results about boron removal from wastewater with ECP (Electrolytic-Catalytic Precipitation).
A way to solve it is to fit an ECP unit to you for testing or to do testing some samples to our partner in Scotland on a sample wastewater quantity (about 5 US Gallon).
Please send me other wastewater analysis and flow rate.
- Constanta, Romania
A. Mr Kirman has given you sound advise, that the use of selective ion exchange for the removal of the boron. It does create a concentrate (and the loadings factors of the resins are low comparatively to other resins), however it is likely the only means by which you may achieve the discharge concentration desired. He also provides to you sound advice that you should probably look upstream for the sources to minimize the capital requirements, which are typically based on hydraulic flows as much or more than the concentration based criteria.
Boron does not convert to an oxide by means of electrocatalytic precipitation nor any other means of electrolytic oxidation. It is stable in solution. This is proven time and time again in the plating of nickel and other metals that rely on boric acid as a buffer. Please show us the data supporting this approach.
Tom Baker
wastewater treatment specialist - Warminster, Pennsylvania
Effect of high boron on lime consumption in Fluoride precipitation process
Q. We have a waste water treatment system that uses lime to reduce
180 ppm of fluoride to 10 ppm. The system was designed to handle a maximum boron content of 130 mg/l in the waste water. In real life, the waste stream contains 1300 mg/l of boron and now we can not reduce the fluoride in the effluent stream below 18 to 25 ppm. We tripled the lime flow and still we are not able to go below the 15 ppm (the pH of the precipitation basin will not increase above 8.7). The system can not be changed, however, we can get a variance on the
10 ppm if we can show by a technical document the effect of boron on the precipitation of fluoride. Modification of the system is not feasible at this time. Please provide any references or technical articles that may address this or a similar problem.
Thank you for your attention
- Barberton, Ohio
by A. V. Topchiev
on Amazon or eBay
A. Here is an excerpt from a UN report on Boron. You may find some insight. I can run some thermodynamic equilibrium curves on the concentrations, if I knew more about the water chemistry. In the absence of such data, I can suggest you add a little phosphoric acid to the water in a beaker/jar test and see if the precipitation performance gets better. I suspect the borate ions are adsorbing onto the calcium, which already has limited surface availability when you use lime, and not CaCl2. The concentration and pH would drive the reaction in that direction. If I find any more references, I will post them.
"Boric acid is a very weak acid, with a p Ka of 9.15, and therefore boric acid and the sodium borates exist predominantly as undissociated boric acid [B(OH)3] in dilute aqueous solution below pH 7; above pH 10, the metaborate anion B(OH)4 becomes the main species in solution. Between pH 6 and pH 11 and at high concentration(>0.025 mol/litre), highly water soluble polyborate ions such as B3O3(OH)4, B4O5(OH)4, and B5O6(OH)4 are formed.
Biggar & Fireman (1960) determined that the fixation of boron in soils occurs by one of three mechanisms: physical (molecular) adsorption, in which the boron is held to the surface of the soil by van der Waals bonds; anion exchange; or chemical precipitation. Chemical adsorption involves ionic and covalent bonding. The investigators speculated that the initial adsorption is probably molecular in nature, followed by the formation of surface compounds that result in an increase in adsorption sites, particularly at higher boron concentrations in the soil solution. At higher concentrations, chemical bonding of borate ions with hydroxyl ions on the soil surface results in boron fixation to soluble aluminium, silicon, and iron.
This same mechanism (chemisorption) was observed by Couch & Grim
(1968) for the uptake of borate ions to clay mineral surfaces. The presence of calcium ions, drying, and high pH values will tend to increase the amount of fixed boron. Wetting and drying of the soil will increase the maximum adsorption capacity and bonding energy of the soil for boron."
- Brea, California, USA
A. Boron and Fluoride do indeed form complexes. My experience on this subject comes from the treatment of fluoborate
(BF4-) plating bath rinses. It is just about impossible to meet a total fluoride limit when treating these rinses. The BF 4- ion hydrolyzes rapidly to BF3(OH)- and then to BF2(OH)2-, and then very,very slowly after this. Since most of these fluoborate solutions have been replaced by methane sulfonic acid solutions, this particular fluoride treatment problem has largely disappeared.
It is likely that you are forming some borofluoride complexes such as BF(OH)3-. These complexes are not precipitated by calcium chloride or by lime. However, in a total fluoride analysis, preceded by a distillation step, it will test as fluoride ion.
Is it possible to locate the source of the boron and isolate it from the fluoride? That would probably make the lime precipitation work.
Other possibilities include adding some phosphate to your precipitation process, or a final polish using activated alumina. Phosphates such as hexametaphosphate and sources of phosphate like bone char have been used to enhance fluoride removal in precipitation systems.
Activated alumina is used as an ion exchange media that can remove and concentrate fluorides. The fluoride ion can also be regenerated off of the media and sent back to the lime treatment system. Activated alumina is capable of removing fluoride to < 1 mg/L.
Q. I need an help about removing of boron with activated carbon. in the literature there are some articles about it. however there is not any detailed information. How much of the boron can be removed by activated carbon?
ebruGNS Treatment Tech. - Turkey
Q. I would like to ask from others regarding the treatment of high boron influent from leachate wastewater. The leachate wastewater originated from the hazardous waste landfill. I've done few test on chemical precipitation with zinc sulphate
and ferrous sulfate
Amazon [affil link] . Both chemicals give 50-65% removal of boron. The influent boron concentration is around 150-200 ppm. Is there any other experience in removing boron from wastewater using chemical precipitation. ( RO systems are very expensive and not feasible ).
Another question that I have is my treated wastewater especially from the leachate wastewater turns black after storing in the tank for few days ( without any movement ). I believe that the black color is due to the FeS that presence in the water. I tried to aerate the water and add some sodium hypochlorite to accelerate the sulfide oxidation to sulphate. However, it seems that it takes along time to oxidize the FeS. ( adding the hypochlorite oxidizes the sulfide and produced Fe(OH)3 sludge ). My question is is there any way that I can solve the issue and should I aerate and add some oxidizing agent in the equalization tanks prior the treatment with ferric chloride
Amazon [affil link] ?
Highly appreciated if anyone can contribute some ideas.
Sr. Process Engineer - Leachate Treatment Plant - Malaysia
A. Muhamed Jaffar
For the Fe problem you should use chlorine dioxide to oxidize the sulfides; I would add it into the stream entering your holding tanks
water treatment - Sacramento, California
December 5, 2011
Q. What may be the chemical reaction for removing BORON from existing water sample.
What shall be the Chemical / ingredients to be used.
- Kolkata, India
Q. Hi
May I know the effectiveness of using Nanofiltration? Will Nanofiltration at 0.2 micron nominal size work for boron removal? How good is it?
- KL, Malaysia
Q. I have two dear friends who have moved to Comptche, CA.
And as they understand it, it is difficult to grow a garden there because of the Boron in the Well Water.
If someone knows the answer for removal or a way around it let me know.
student - Caspar, California, USA
A. Dear Pamela,
Please warn your friends NOT to use the well water as it is contaminated with Boron. Boron has been known to cause low fetal weight and also atrophy of the male and female sexual organs. Please be very careful.
- Malaysia
A. Removing boron from drinking water can be very expensive -- typically out of the realm of affordable for most people. It doesn't respond well to ion exchange or reverse osmosis. The best one might be able to do is use bottled water for drinking, along with contacting your local, State, and Federal regulatory agencies (DOH, State env. dept., EPA, even USGS). Check EPA's website for information to find out if the occurrence might be related to a site or facility. It could be naturally occurring.
Do your friends have the option of connecting to a public water source? Again, I would contact the agencies listed above first and foremost.
consulting - Andersonville, Georgia
March 8, 2011
A. Chemical precipitation is the best way to remove boron. Usually precipitates out at ph above 9+ followed by acid adjustment.
John StidwillOttawa, Ontario, Canada
A. We have used peat for boron removal, in the first stage we compared four kinds of adsorbents Basalt, peat,compost and activated carbon and we found peat is the best. the result of this part of our study will be published in journal of environmental technology "INVESTIGATION OF ORGANIC, INORGANIC AND SYNTHETIC ADSORBENTS FOR THE PRE TREATMENT OF LANDFILL LEACHATE". Then we compared three kind of peat to find which one has the best performance and finally we did field studies. The result of this part of the work will be submitted to publish very soon, too. Also we compared the effect of environmental factors on adsorption of boron from landfill leachate. The result has published "Adsorption of boron from landfill leachate by peat and the effect of environmental factors".
Haleh Shahriari- Ottawa. Ontario, Canada
February 25, 2008
⇦ Tip: Readers like to learn from others' situations;
Q. My question is what other options can be used to remove boron from wastewater to 0.3 ppm level.
Alaa AnnaniCivil engineering - Woloonogong, Australia
October 20, 2013
A. Using ion exchange resin you can reach 0 ppm of Boron
Albino trussi- milano Italy
April 7, 2014
