-----JF-500 or JS-500 Finish ?
Have you heard of a finish called JF-500 or JS-500 ? I believe it's a zinc plating finish with an organic top coat. If anyone has any knowledge of this finish It will be very helpful. Thank you in advance, Enrique
Enrique SegoviaMonterrey, Mexico
I see that this inquiry has the same subject as an letter, #3021, Mr. Segovia. So further postings would probably be better continued there. Regards,
JS500 is a zinc and colour process which has 500 hours salt spray test to white rust.
Richard Wells- England
