-----Anti-reflective process for 416 stainless
I have an optical assembly made of 416 stainless steel that is giving me reflecivity problems. I'm looking for a means of giving it a low-reflectance surface. Paint is not a good option, because lenses must be epozied to the surface and masking these areas of the surface is extremely difficult. Also, cleaning of the lens with acetone ⇦ on eBay or Amazon [affil link] Flammable! is likely to mess up the paint and possibly smear it onto the lens.
I prefer a chemical process which alters the color/ reflectivity of the metal's surface, will allow epoxy adhesion similar to that of the untreated surface, and will cause minimal out-gassing in a vacuum environment.
That's a tall order, but does anybody have any suggestions. . . please?
Andy ChouinardConway, Arkansas
I'd look at a thin PVD coating, maybe 0.2-0.3 microns thick. If it's a Zone 1 coating it will have an open columnar structure, making it a poor optical reflector. As the coating is applied in a vacuum, it is certainly vacuum compatible -- more so than any chemical coating. Most job shop houses won't do the job, but you should be able to find a bell jar e-beam or sputter system at a university or on the used equipment market. Colorado School of Mines in Golden, CO, has a couple of units that could be used, as well as students to do the work, assuming that the assembly is not too large.
PVD Consultant & Wine Lover
San Diego, California
I feel that a black coating would do a good enough job. The possibilities are black oxide type coating or passivation, or back chrome plating.
Mandar Sunthankar- Fort Collins, Colorado
