finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 3602
Need Aluminum Ion Vapor Deposition Service (IVD)
(1999)
I am quoting some jobs for a customer and am trying to find a shop that does "Aluminum Vapor Deposit". Can Someone help me, I've never even heard of this.
Bill M [last name deleted for privacy by Editor]
- Wilmington, Massachusetts
  ^- Sorry! This RFQ is outdated -^
(1999)
We are looking for a source in the mid-west for IVD aluminum plating and would appreciate any leads.
PS
Patrick S. [last name deleted for privacy by Editor]
- Mishawaka Indiana
(2003)
Hello,
IVD is a replacement product for Cadmium. Does anybody know a company in Europe that can do IVD for our company?
Greetings,
Peter A [last name deleted for privacy by Editor]
aerospace - Eindhoven, The Netherlands
(2007)
I am looking for someone in the southeast (this is critical) that can do IVD Aluminum per MIL-DTL-83488 class 1 type 1
Thomas P [last name deleted for privacy by Editor]
Specialty parts manufacturer - Greer, South Carolina
(2007)
IVD aluminium coat per mil-c-83488 type2 class3. This spec is required on castings with a batch size of roughly 60 parts. This may be around 10 times per year. Having difficulty locating more than one sub-contractor in the UK.
Duncan Collinson
investment casting foundry - York, North Yorkshire, UK
January 29, 2008
Supplier of high purity aluminum 5 pound bar and shot up to 99.997% Al needs Aluminum Ion Vapor Deposition Service
Jon S. [last name deleted for privacy by Editor]
Manufacturer - Euless, Texas
October 15, 2008
Dear all,
I am looking for someone in Europe able to perform IVD coating on stainless steel, according to MIL-DTL-83488.
Can someone help me?
Thanks in advance
Raffaele C. [last name deleted for privacy by Editor]
product designer - Brussels, Belgium
June 12, 2009
Hi, my name is Oscar Gutierrez and I am looking for IVD alum class 2 type II process, I am working to the aerospace industry, if you give me your e-mail I send you the drawings and qtys
Oscar Gutierrez
- Zapopan, Jalisco, Mexico
July 27, 2009
We are requesting quotes for IVD aluminum deposition on small metal shells for minimum orders to 1,000 pieces.
John W [last name deleted for privacy by Editor]
buyer - Springfield, Missouri
August 3, 2009
Hello,
I'm in need of a price quote for plating of the test coupons type 1d (notched C-ring) detailed in ASTM F519 [link is to spec at TechStreet]. The details are listed below.
48 samples at each of the following:
1) LHE Cd Plating-The LHE Cd plated specimens shall be plated all over following QQ-P-416 [link is to spec at TechStreet] Type II (with supplementary chromate conversion coat applied after bake), Class 2 (0.0003 to 0.00049 inch thickness).
2) LHE Cd Plating with Bare Notch Area-The LHE Cd plated specimens to be tested with a bare notch area shall be masked and then plated in accordance with QQ-P-416 Type II (with supplementary chromate conversion coat applied after bake), Class 2 (0.0003 to 0.00049 inch thickness). Masking Prior to Plate-The notch and approximately ? inch on either side of the notch shall be masked to prevent Cd deposition.
3) IVD Aluminum coating following MIL-DTL-83488 [link is to spec at TechStreet]D, Class 2 type II coating.
If you have any questions, feel free to call me. Thank you so much!
Jane Pitchford, Project Engineer
consulting - Jacksonville, Florida
September 17, 2009
Hi,
I am looking for a business that can perform an Ion Vapor Deposited Aluminum Coating per MIL-C-83488.
Material to be treated -- 4340 Steel COND C SAE-AMS-S-5000
Heat Treat to 150 KSI UTS Rockwell C 34-38 per SAE-AMS-H-6875
Parts will be shot peened
**Apply Aluminum Coating per MIL-C-83488, Class 1, Type II. Do not plate holes**
25pc 1.25" x 2" x 8.25"
25pc 1.5" x 2" x 15.75"
25pc 2" x 2" x 10.75"
Each Part will have 3 holes ranging from 3/8" to 15/16" and the holes are not to be plated.
Anthony Papist
FAA Repair Station - Newberry, Michigan, USA
October 14, 2009
I am looking for vendors to bid on IVD aluminum coating per MIL-C-83488 (or equivalent - spec is actually updated, it is now MIL-DTL-3488, but I can get by with out certification to either of them). I have 234 Sleeve Bolts that are approximately 3/8" dia x 7/8" long each. Thank you for your consideration.
Andy Drumheiser
contract manufacturing - Barrington, New Jersey, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
